E4OD Transcommand install
Old Dec 18, 2020 | 11:54 AM
Greg-93’460's Avatar
Greg-93’460
Anybody done the Transcommand from Banks on an E4OD?
Just finished it up last night but didn’t have a chance to drive the truck to test it out. I started the truck this morning and shifted through all of the gears for a minute before I left for work. No OD light flashed as an error or anything? 🤷‍♂️
Do you remember what wire colors came out of slot 1,11&12 on the transmission harness?
Just want to make sure I had the plug oriented the right way 😬😬 got to thinkin, while I’m sitting here at work counting the seconds till 5pm on a Friday with my truck waiting for me at home 😂🤣
I think i did it right because on the install sheet it says #1 is typically red and mine was solid red which makes me feel better. But it doesn’t say the other colors
Old Dec 18, 2020 | 12:47 PM
rla2005's Avatar
rla2005
The solenoid pack connector, C1048, diagram:
Pin 1 = Red
Pin 11 = White/Yellow
Pin 12 = White/Red
Old Dec 18, 2020 | 01:06 PM
Greg-93’460
HECK YES.
Thabks so much for the translation too. I’m new-ish to trucks so I got lots of learning and tinkerin’ to do.
Thought I might have gotten in over my head last night😂 hands barely fit where they needed to go. Took me lot longer than what they said it would take.
Now I just have to wait to get home, have dinner, spend time with the family before I try it out. 😂
Old Dec 19, 2020 | 11:38 AM
Greg-93’460
Went for a drive with Transcommand on and either I did something way wrong, or it changed my trans for the worse...
I now sound like an airplane taking off every time I accelerate from a stop. It’s a really slow get off both if I stomp on it or slowly accelerate.
Rpm won’t go above 2500-2700 even floored on the highway.
Trans temp spiked to 150 with a few trips around the block and 1 1/2 mile stretch of highway.
I put the bypass plug in to compare apples with oranges and it did way better but still wouldn’t accelerate like it did before.
Any experience? I tried calling banks install help people but they’re closed saturdays. 🙄
I’ll try and post a video but they typically don’t post from my phone for some reason. 🤷‍♂️
Old Dec 19, 2020 | 12:00 PM
Greg-93’460
I just ran codes and found 41(system lean HEGO sensor out of range, 26 (trans temp sensor fault)
Old Dec 19, 2020 | 12:01 PM
Greg-93’460
heres at attempt at the video post
Old Dec 20, 2020 | 08:45 AM
grumpyinme.'s Avatar
grumpyinme.
I have a trans command on my 94cf250,love it,made a big difference.
Old Dec 20, 2020 | 09:36 AM
Greg-93’460
aby suggestions on how to fix mine so it works? 🤷‍♂️
I think I need to check my wiring in see
ated properly. Anyway to test if it’s all connected? And touching? 🤷‍♂️🤷‍♂️
I checked my wiring colors and they match where they’re susposed to be.
Alkaline198
Apr 21, 2025 09:21 AM
10strokin
21
Oct 27, 2015 11:18 AM
pro70golfer14
Oct 12, 2009 07:01 PM
4xfordman
1978 - 1996 Big Bronco
28
Aug 17, 2007 10:47 AM
texaspride250
Jan 27, 2003 05:49 AM
