Small coolant leak
Old Dec 15, 2020 | 10:04 AM
MTP55's Avatar
MTP55
Small coolant leak
What is this part called that the thermostat mounts to? Its on a 2006 Explorer. Every vehicle i have has the thermostat on the water pump. In the one corner you can see a small coolant weep. Thanks in advance.
Old Dec 15, 2020 | 11:17 AM
DILLARD000's Avatar
DILLARD000
Pic looks NOT to be the F150 noted in your profile, but a 2006 Explorer with V6~4.0L~SOHC engine?
The infamous PLASTIC ThermoStat Housing!
Yours has a SingleClipMountedTempSensor & ForewardFacingTopCoverOutletRadiatorHoseBarb.
These FactoryOE\AfterMarket PLASTIC Housings are well known notorious leakers.
Best to replace\upgrade to an Aluminum ThermoStat Housing & new ThermoStat Valve.
Your local parts house will likely set a cheap PLASTIC housing in front of you
& does not stock Aluminum Housings; online RockAuto\Amazon\Ebay have them with price comparable to Plastic Housing.
Several items look rusty\crusty; Michigan winter road salt?
If any of your Coolant system Hoses, HeaterControlValve,HeaterCore Pump+Fan+Clutch, Radiator...
have never been serviced\flushed\replaced, it's time. The hoses+clamps look original.
While replacing the ThermoStat Housing, is a good time to replace the OilPressurized TimingTensioners;
that left TimingTensioner looks original?
More info on doing this at
http://2001fordexplorersporttrac.fan...ant_ThermoStat
http://2001fordexplorersporttrac.fan...mingTensioners
http://2001fordexplorersporttrac.fan...an+Clutch+Pump
http://2001fordexplorersporttrac.fan...nt_HeaterValve
http://2001fordexplorersporttrac.fan...t_Radiator+Cap
Hope this helps.
Old Dec 15, 2020 | 11:42 AM
MTP55's Avatar
MTP55
Thank you. Its actually a vehicle my boss just bought for his wife to drive, even though she doesn't like it. I personally think its better than her clapped out 2010 town and country van but I'm a Ford guy. I will let him know. The tensioner must be similar/the same as the ones on my brothers 06 Ranger with a 4.0. Ill keep that in mind too. And yes, this vehicle lives in MI.
Old Dec 15, 2020 | 11:47 AM
MTP55's Avatar
MTP55
Possibly a stupid question. Are these front wheel drive when 4x4 is off or rear wheel drive like a pickup?
Old Dec 15, 2020 | 12:16 PM
DILLARD000's Avatar
DILLARD000
Assuming Explorer is 4WD equipped.
When 4WD is OFF, power is to the rear.
When 4WD at 4WH, power is to all wheels with hi gearing; ok for higher speeds.
When 4WD at 4WL, power is to all wheels with lo gearing; lo speed driving only.
Old Dec 15, 2020 | 12:18 PM
DILLARD000's Avatar
DILLARD000
PS:
Yes the same Tensioners are used in all Ford V6~4.0L~SOHC engines.
Old Dec 15, 2020 | 12:27 PM
MTP55's Avatar
MTP55
Thanks. I'm trying to figure out why it pulls to the right. Front wheels spin hard. But looking at the calipers and rotors I think I found his issue.
Berardini2121
1978 - 1996 Big Bronco
May 11, 2016 05:31 PM
Steven111
Dec 21, 2015 01:21 PM
John SCB
Feb 22, 2010 04:08 AM
98FordTruck
1997 - 2003 F150
Jan 14, 2009 09:13 AM
Farmboypowerstroke
Aug 25, 2008 10:10 AM
