Leaking coolant
Old Aug 22, 2008 | 01:34 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
Leaking coolant
I put in the 203* thermostat and changed my coolant a few weeks ago, and its been leaking ever since, it must be the thermostat housing??? where is the best place to buy one?
Old Aug 22, 2008 | 01:39 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
This is what lots of us get.
Old Aug 22, 2008 | 01:42 PM
miller_feed
Here is the link. click here
Old Aug 25, 2008 | 09:52 AM
Farmboypowerstroke
thanks, I just ordered mine, hope it doesn't leak anymore
Old Aug 25, 2008 | 10:10 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Be sure it's leaking from the t-stat housing. When I did the flush & fill (with Rotella ELC) my pump finally gave up the ghost (@140,000miles). If it's coming out the weep hole, you'll probably not be able to see it except for where it's dripping off your harmonic balancer. Swapping out the water pump is actually pretty easy, just make sure you get/borrow/rent the proper tools for removing the fan.
