The headlight search, advice
I understand with some trimming newer headlights will fit and opens up a realm of possibilities to include, led, projectors, etc. I’m not sure I’m a fan of such a drastic change on an older truck. I want to freshen her up but keep her looking somewhat 20 years old.
I do like the look of the Euro style headlight housing which is nothing more than a clear flat lens vs the factory. That said everything seems to be low rated plastic cheap stuff with poor reviews.
Anyone have any insight on decent quality replacement headlights and marker/running light assemblies? Thanks, Rye
below is one option but it has some good and terrible reviews and I’m sure it’s lightweight plastic throw away stuff.
I know us truck guys, my buddy has changed lights 4 times on his 2016 Ram, lol.
There’s been some posts about the topic but I can’t remember exactly where at the moment... I’ll go looking and maybe add an edit if I find it.
I believe he recommends Eagle Eyes 2003 clear style with a special wiring harness (I’ll let him tell you which one) and Hella bulbs. Again, wait for him to clear up my mistakes. I’m off to search for the thread.
From what I gather adding the relay harness is the biggest way you’ll get better light.
Edit: found the one I was thinking about. https://www.ford-trucks.com/forums/1...my-lights.html
FordTruckNoob made his own out of a sealed beam LED housing (I think...) and they do a great job.
The alternative that most of us go with is something like what you have above. I installed clear lenses and a relay wiring harness with some quality bulbs and it made a huge difference. The OEM wiring to the headlights is a joke...
SkySkiJason has some great information on headlight, harness and bulb sources. I thought the information was in the Tech Folder, but I didn't see it during a quick scan just now. Perhaps search for his name and some related terms in the subject line. If you cannot find what you are looking for, I will find them and post them here. Jason also recommends Hella 80/100w bulbs ONLY after upgrading the harness.
I recently replaced my running light housings after 7 years of using a clear lens. I run a chrome/amber bulb in the housing as well in order to give it that 100% clear lens look, but retain the amber turn signal and running like look.
The previous running light housing I used had the clear vertical lines in the lens and I wanted to get away from that, so I bought some from 1A Auto that are clear without the vertical lines.
Source: https://www.1aauto.com/products/i/1A...nfirmation+Old
The price was a bit more, but since the other housings lasted 7 years, I figured an extra $20 was worth it for the look I wanted.
I don't drive my truck during hours of darkness a lot, so the clear lens with the relay harness gets the job done for me. If I were driving during hours of darkness, I would without a doubt go for the Morimoto or FTN option. No matter what you do, seriously consider the relay harness at a bare minimum.
This site and the people on it are fantastic.
Thanks again and have a great weekend, Rye!
Many drop in LEDs put out a wall of light with no cut off. Looks brighter but they don't put light down the road and blind oncoming traffic. Please research which bulbs work in composite housings to get you the cut off you need if you go this route. I've also heard brights aren't any brighter with these so consider that for your back road driving. I like @colorado350 set up with sealed beam LED trucklites if I were to go LED.
https://www.ford-trucks.com/forums/1...tes-led-s.html
Ill put up pics so there are part numbers to reference. Some of the stuff won’t be here for awhile but I will post up pics here when it’s done.Thanks again!
High beam, slight up hill grade at the stop sign.
Cut-off at maybe 50 feet.
