Help with plug identity
Old Dec 11, 2020 | 11:10 AM
emeraldcoupe's Avatar
emeraldcoupe
So I'm missing the other half of this plug, 71 f100, it's near the starter solenoid. I know it's a power wire but have no idea where it goes to, the original was eaten by rats. Is it available, or does anyone have it on a parts truck?
Old Dec 11, 2020 | 11:19 AM
eric8's Avatar
eric8
I found a post where another guy was asking about the connector labeled "m8815" like yours, and this was what he said:
"The wiring is straightened out. The yellow wire itself just needed to be put back in line with the solid black wire from the alternator. The red wire that led into the fusible link and then came out as a yellow wire went to the battery terminal on the solenoid. All wired up, harness is wrapped back up and everything is working great."
Old Dec 11, 2020 | 11:32 AM
GrandpasOldF250's Avatar
GrandpasOldF250
That black/yellow wire is the main power wire that goes into your cab (12v constant). The red and yellow wires both go to your ammeter (amp gauge on your cluster). Here's a wiring diagram that's helped me a ton. If you're looking for a new plug your best bet might be finding someone that's done a 3G/1wire alternator swap on their truck cutting that plug out. A lot of times to clean up the wiring on those alt swaps the black/yellow wire goes to 12v+ on the battery then the red and yellow wires get cut since the factory ammeter wont work with a high amp alternator.
Old Dec 11, 2020 | 12:49 PM
emeraldcoupe
Thanks guys, I figured out the main power wire, not concerned about the others, I'll be running a 3g. Thanks again for the help
dallasf150
113
Jan 22, 2020 05:14 AM
saz2686
Modular V10 (6.8l)
Apr 6, 2012 01:22 PM
Fordby4
Jul 17, 2010 04:22 PM
mblanken881
Jan 17, 2009 04:47 PM
JohnT
Apr 23, 2005 05:56 PM
