Engine Block Heater Power
Old Dec 11, 2020 | 08:14 AM
MBaldo's Avatar
MBaldo
2019 Ford F350 6.7 Lariat
Question ... When you plug in your engine block heater, does it also trickle the batteries?
Old Dec 11, 2020 | 08:37 AM
speakerfritz's Avatar
speakerfritz
no..the block heater connection directly powers a resistive element in isolation of the entire truck electrical system.
Old Dec 11, 2020 | 08:59 AM
johndeerefarmer's Avatar
johndeerefarmer
Why would you want to do both from one plug? If you were going to drive the truck soon you would have the heater plugged in. If you were not driving it soon and wanted to keep the batteries charged you wouldn't want the heater on all of the time?
Old Dec 11, 2020 | 09:01 AM
MBaldo's Avatar
MBaldo
I was told it charged the batteries as well, but was skeptical. That's why I asked the question. You guys know more about these trucks than anyone.
I appreciate the feedback.
Old Dec 11, 2020 | 09:02 AM
johndeerefarmer
Gotcha...... Have a good day
Old Dec 11, 2020 | 09:26 AM
MBaldo's Avatar
MBaldo
I don't drive the truck much during the winter months and was wondering. I used to put two trickle chargers on my last truck. For those who don't drive them much on the winter .. it would be nice if the plug handled both.
Old Dec 11, 2020 | 10:05 AM
carl2591's Avatar
carl2591
no reason you could not install a 120v trickle charger that was on the heater plug circuit so when you plug in heater the trickle charge is in service as well..I used the harbor freight deal and it works great.. and does not over charge or boil the batteries.. just keeps a 13.3 volts with little amp flow. perfect for low use in cold weather.. you could also hook the system up to a size appropriate size timer to turn on the heater each day for a couple hrs along with the charger.
Old Dec 11, 2020 | 10:32 AM
Pugga's Avatar
Pugga
If you don't drive the truck much, I would think you would NOT want them tied together. The block heater should really only be plugged in about 2-4 hours before you plan to drive the truck, otherwise you're just wasting electricity heating up the block for nothing. A battery tender is to keep the batteries in good shape while the truck isn't actually running.
For my, my 6.7 is my daily driver. When it's cold, I have an exterior plug on a timer for the block heater. I plug it in the night before when I get home from work. The timer 'goes live' at 2 AM and I start it and leave for work around 5 AM. If the truck is going to sit for days on end, I don't plug it in, no need to waste the energy.
Old Dec 11, 2020 | 10:47 AM
hindy's Avatar
hindy
Quick question and I'm sure i can search but thought I would save time with folks in the know. When trickle charging, do you need them on both batteries or just the one since they are in parallel?
Old Dec 11, 2020 | 11:28 AM
water_junky's Avatar
water_junky
I have an on board battery tender for keeping the batteries charged when it sits most of the winter. I have a single outlet in my airdam that feeds both my engine heater and my charger but I have a solid state relay hooked up to an outfitter switch that only provides power to the engine heater when the switch is flipped. I also have a light near the start button to tell me that the truck is plugged in and if I don't see it and start the truck a buzzer will sound until the truck is unplugged.
Old Dec 11, 2020 | 11:44 AM
tibadoe's Avatar
tibadoe
No. I attached lead to passenger side battery and it keeps both charged and desulfated.
Old Dec 11, 2020 | 12:20 PM
Pugga's Avatar
Pugga
That buzzer would be really handy! I put something on my steering wheel when I plug the truck in to remind me not to drive off without unplugging. It's not fail-safe, but it's the best I have at the moment...
Old Dec 11, 2020 | 12:28 PM
hindy's Avatar
hindy
Super! Thank you....
Old Dec 11, 2020 | 01:28 PM
MBaldo's Avatar
MBaldo
This question I had was answered above.
paulhump
6.4L Power Stroke Diesel
Apr 5, 2017 03:02 PM
2gumby2
2015 - 2020 F150
Apr 6, 2016 11:30 AM
DH44
6.7L Power Stroke Diesel
50
Dec 17, 2013 01:43 PM
LOADED 06 PSD
Jan 27, 2009 12:39 AM
84 Diesel
Feb 3, 2005 05:54 AM
