Engine Block Heater ?
Old Dec 13, 2013 | 06:33 AM
DH44's Avatar
DH44
Is there some trick to the engine block heater? I mean, it's a simple plug. I've plugged mine in several times, to different sources, and nada. I can't imagine it's fused or anything like that. Do you need to plug it straight into Browns Ferry or something?
2012 F250 with 33k miles.
Old Dec 13, 2013 | 06:54 AM
Romeo Scorpion's Avatar
Romeo Scorpion
What do you mean by nada? There is no light or any indication that it's on. It's simply an 850 watt heating element.
Old Dec 13, 2013 | 07:01 AM
Hdslider's Avatar
Hdslider
nada= nothing. lmbo
Old Dec 13, 2013 | 07:04 AM
Romeo Scorpion
Yes. I know. I was asking what he meant by nothing happening when he plugged the block heater in.
Old Dec 13, 2013 | 07:05 AM
ct diesel's Avatar
ct diesel
simple question is did you check to see if you had electricity at the outlet? Alot of times you will find a blown fuse or tripped breaker. Just something to check.
Old Dec 13, 2013 | 07:08 AM
Romeo Scorpion
Sometimes you need a little clarification. I knew someone that believed if they plugged their block heater in, their truck would be warmed up when they got in and started it. When that didn't happen, he thought the block heater wasn't working.
Old Dec 13, 2013 | 07:27 AM
Hdslider's Avatar
Hdslider
Possible his expectations are plug me in and shazam it should be hot. not gonna happen.
1St dvom cord and see if have voltage.
2nd ck resistance on block heater element.
3 if still in doubt purchace a amp watt tester and you can see how many amps/watts its pullling. there very affordable.
Old Dec 13, 2013 | 08:00 AM
DH44's Avatar
DH44
Nada. Plug it in, the cord is heavy duty and live. Tried it in several outlets, didn't trip any of them but it did not heat up the element at all. The cord didn't even warm up.
I know it won't turn the cab into a sauna. I thought I read somewhere it would stay on for 2 hours or so and then turn itself off. But I've never been able to get it to heat in the first place.
Old Dec 13, 2013 | 08:15 AM
rob92761's Avatar
rob92761
some of the old block heater if you plug them in slow enough you would get a small spark at the plug indicating that it was working.
Old Dec 13, 2013 | 08:35 AM
Hdslider's Avatar
Hdslider
DH44. Maybe your block heater element took a crap. You can ohm it if you have Dvom. Or buy a watt/ amp checker. Lowe's home depot etc. There cheap. Plug your cord into it and to outlet and you will no if its working. It will show you amps and watts its pulling.
Old Dec 13, 2013 | 10:57 AM
marchare011's Avatar
marchare011
I'm going off of a pi** poor memory here, but, doesn't the cord come separately from the dealer? If so, that would mean that it connects to the block heater via some sort of connector. Could it possibly have come loose or was never connected at the block heater end?
I would go look at mine but I'm too lazy and it's too cold to lay on the ground right now.
Old Dec 13, 2013 | 02:17 PM
MPD56's Avatar
MPD56
My block heater wouldn't work either, used a ohm meter to verify. Brought it to the dealer and they said that the connector was loose from the factory.
Old Dec 13, 2013 | 03:22 PM
PlayersZ28's Avatar
PlayersZ28
Was going to ask a stupid question but then I went and looked and found the plug in the bumper.
Decided to test mine but couldn't find my meter so a battery and LED sufficed to show me I had continuity across the plug. Good to go now when it gets real cold, has only been down to -15c so far.
Old Dec 13, 2013 | 03:34 PM
Jigger2020's Avatar
Jigger2020
I have a plug alive block heater tester
Old Dec 13, 2013 | 04:57 PM
golfmedik's Avatar
golfmedik
The 6.7s do not come standard with a block heater. Only trucks that are bought in 11 states. Mine here in GA didn't have one. That's why there is an element and cord lying in my garage to put on mine when I have the time.
