Sponsored by: Real Truck
Code P2160
Old Dec 9, 2020 | 09:36 AM
Plumberjeff's Avatar
Plumberjeff
Code P2160
Having problems with my 2016 F250 6.7 6spd auto Platinum 4wd. I keep getting a code P2160. Anyone know how the vss system works on these trucks. Location of sensor or did Ford switch over to a module?
Old Dec 9, 2020 | 11:13 AM
Just Strokin's Avatar
Just Strokin
I didn't see a 2160 DTC. Is this a P or B or U DTC? Most likely you have a bad wheel speed sensor on one of your front hubs.
Old Dec 9, 2020 | 04:29 PM
Plumberjeff
Sorry it is a P2160 DTC
Is there a way to test the wheel speed sensor?
thank you
Old Dec 10, 2020 | 07:13 AM
projectSHO89's Avatar
projectSHO89
Gas or diesel? Manual or automatic?
Details are important. Include them.
Old Dec 10, 2020 | 08:56 AM
redford's Avatar
redford
FTE Leadership Emeritus
It's a 2016 Power Stroke.
Did the 6.7L PSD ever come with a manual transmission option?
Old Dec 10, 2020 | 06:25 PM
projectSHO89
Unfortunately, my service library only goes up to the 2014 MY so extending that to the '16 MY would be speculative. Take the following FWIW since I don't have newer data. Maybe someone else does and can chime in...
I can't find that DTC in any of documentation for any of the several trucks I did check. Google search yielded several hits but they are of unknown quality and of very dubious origin. Like many Google hits for DTC searches of manufacturer-specific fault codes, they could be from another make and model. Unknown.
Since VSS data is supposed to come from the ABS system on this generation of Super Duty, my best suggestion is to scan the ABS system for any DTCs specific to that sub-system and see if anything interesting is revealed.
cjben
Jan 2, 2021 07:22 AM
winter123
1997 - 2003 F150
Sep 27, 2009 07:50 AM
Goulette55
Jan 20, 2006 09:19 PM
rmarion
1983 - 2012 Ranger & B-Series
Sep 19, 2004 07:51 PM
