code 659 anyone?
Old May 23, 2011 | 08:51 AM
cjben's Avatar
cjben
code 659 anyone?
1995 f150 5.0 4wd auto trans. Truck doesn't start,not getting spark,only code in the computer is code 659,"high vehicle speed in park indication". Huh? the truck hasn't move in 4 months,so is this a bs code,and if not,what does it mean? I don't think this code means anything related to my no spark condition,but just want to be sure before I do a bunch of troubleshooting and buying parts.
Old May 23, 2011 | 07:45 PM
rla2005's Avatar
rla2005
Never ran across that code before. In my opinion that is a B/S code that has nothing to do with your no spark condition. FWIW that code is not listed in my Ford Truck EVTM manual.
Old May 24, 2011 | 06:42 AM
cjben's Avatar
cjben
yeah,I couldn't find it here when I searched,but it did come up in my code reader,and it is in the book of codes,so I thought I would see if anyone had heard of it.
Old May 24, 2011 | 06:43 AM
Lazy K's Avatar
Lazy K
If it is a code from when the truck was driving my guess would be a bad Transmission Range Sensor.
If it is a new code then my guess would be a bad PCM.
But only guesses.
Old May 24, 2011 | 08:05 AM
cjben's Avatar
cjben
it is a new code,I searched google for the code,only found it in reference to cars,but they said the fix could be a pcm problem
Old May 24, 2011 | 10:32 AM
subford's Avatar
subford
From my 1995 Ford Truck EVTM manual.
DTC 659 indicates high vehicle speed detected while the vehicle was in PARK.
Possible causes:
-- Damaged Transmission Range (TR) Sensor.
-- Damaged PCM.
Old May 24, 2011 | 10:50 AM
cjben's Avatar
cjben
what is the procedure to check the computer?
Old May 24, 2011 | 11:04 AM
subford's Avatar
subford
Key off.
Connect TR sensor.
Breakout box installed, PCM disconnected.
Unlock steering column.
Measure resistance between Test Pin 30 and Test Pin 46 at the breakout box in each gear selector position. Refer to the TR sensor resistance specification table below:
Is each resistance within specification?
Yes
REPLACE the PCM. REMOVE the breakout box. RERUN «Quick Test».
No
REPLACE TR sensor. REMOVE breakout box. RERUN «Quick Test».
Old May 24, 2011 | 04:55 PM
cjben's Avatar
cjben
damn I was hoping there was an easy test!!LOL what is a breakout box?
Old May 24, 2011 | 06:11 PM
subford's Avatar
subford
Just use the pins on the PCM Computer plug for the test.
The BOB (BreakOut Box) is a tester that you plug the PCM Computer plug into and then it has all of the pin numbered holes that you can probe.
The BOB:
Old Jan 1, 2021 | 08:04 PM
Marty Hernandez's Avatar
Marty Hernandez
Circuit 659 ?I would think module down .clutch interlock switch.just food for thought
Old Jan 2, 2021 | 07:22 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Fault code 659 not electrical circuit number. The truck in this 10 year old thread had an automatic transmission. Not checking the last post date sometimes get people bringing up old threads. Welcome to the forum.
sg1099
1997 - 2003 F150
Dec 21, 2010 05:17 AM
