Hardware Battery Minder/Tender
Old Dec 7, 2020 | 01:00 PM
flysniper's Avatar
flysniper
Question Hardware Battery Minder/Tender
Has anyone hardwired a Batter minder/tender in with the block heater?
The idea is that the batter minder/tender would work anytime the block heater is plugged in.
Old Dec 7, 2020 | 01:10 PM
ford390gashog's Avatar
ford390gashog
Yes thats a pretty common setup on equipment I work on. No reason you couldn't do it on a truck.
Old Dec 7, 2020 | 01:48 PM
flysniper's Avatar
flysniper
I am wondering where the appropriate/convenient place would be to tap into that line.
Or is there a suitable place to tap into a fuse box or something similar?
Old Dec 7, 2020 | 02:22 PM
Syphlyn's Avatar
Syphlyn
I did it on my 05...
Made the connection behind the driver side bumper. Tied into the plug coming out the front by the towing hook with a secondary plug behind so I could unplug the battery maintainer in the summer.
For some reason I went through 3 block heaters in a year doing this...unplugged the maintainer and Haven't had an issue since. Idk if the battery maintainer was pulsing and also pulsing the block heater and it burned out. But somehow theyre related I firmly believe.
Got a bigger alternator and new batteries and havn't looked back
Old Dec 7, 2020 | 04:37 PM
joe blow's Avatar
joe blow
I did something similar, but I did one individual for the heater and NOCO charger.
The amp draw might be too much to have them work simultaneously, but I am sure you can look into it.
I hole saw'd the plastic air dam at the bottom of the bumper
Amazon Amazon
Old Dec 7, 2020 | 04:39 PM
joe blow's Avatar
joe blow
The charger I mounted on the right side by the vacuum reservoir. The charger is wired on the right battery and the system charges just fine since the batteries are linked.
Old Dec 8, 2020 | 06:13 AM
kgburns's Avatar
kgburns
Since I only use the block heater for a few hours on the really cold mornings, I left mine separate since the lower amperage Battery Tender (mine is the 5 amp version) wouldn't do much for the batteries for that short period.
And since I leave the Battery Tender plugged up during the periods the truck would not be used, I wouldn't want the block heater operating for that extended period.
Just my take, your situation(s) may be different.
akblackfoot
Jan 18, 2017 12:31 PM
bigdumbtuck
Feb 2, 2009 07:48 AM
the Goat
Mar 6, 2008 11:20 AM
FordTruckNoob
21
Feb 11, 2008 12:52 PM
fastwheeler
Jan 21, 2003 10:37 PM
