Injector copper washers
Old Dec 6, 2020 | 04:08 PM
mack1855's Avatar
mack1855
pulling my injectors to check for a bad o-ring.These were installed in May of this year.checking for a issue with sudden blue smoke out the exhaust pipe.As I check,if they are ok,can I reuse the copper washers
I installed with the new injectors in May?.Or should I get 8 new washers as I pull the injectors to check O-rings,one by one.
I don't know if the washers are still good,after torqueing to specs for the hold down clamps.
Thanks.
Old Dec 6, 2020 | 05:28 PM
96 OBS's Avatar
96 OBS
You should get all new Allient o-rings. Wouldn’t put old ones back in. Not sure about any rules on the copper washers. But as a guess (someone who knows better may correct me) I would reuse the copper washers. But not the o-rings
Old Dec 6, 2020 | 07:57 PM
MJ79's Avatar
MJ79
The copper washers are a one time use item. If the o rings are questionable change them as well. RiffRaff o rings come with new copper washers.
Old Dec 7, 2020 | 12:48 AM
FinnishStroker's Avatar
FinnishStroker
When does the blue smoke appear?
Copper washers crushes when tightened so they can keep away the cylinder pressure.
Changing only external orings is a waste,there are internal orings too.
What size injectors and where did you bought them?
Monster-4
Jul 13, 2020 11:05 AM
johndeerefarmer
Jul 24, 2016 07:13 AM
dwdranch
May 15, 2013 07:24 AM
Onus
Oct 14, 2012 07:01 PM
Jerrod
Feb 20, 2006 07:33 AM
