Body men/painters
Old Dec 5, 2020 | 01:45 PM
rwilly1's Avatar
rwilly1
Body men/painters
My truck is a Ranger that has trim that runs down the bump line.
I’m missing about 1/2 the trim pieces. The bed is rusted out and I want to replace it.
I can buy a replacement bed that is in better shape off a non-Ranger truck even though it doesn’t have the trim and have a body man drill the holes needed to mount the trim.
As a body man, what would you prefer?
What is the level of difficulty to do the conversion?
Are the trim pieces hard to find?
Or do I wait and find a bed off a Ranger that already has all th trim?
thanks
Old Dec 6, 2020 | 10:12 AM
gump1376's Avatar
gump1376
You can find the trim at several of the restoration places; LMC, Dennis Carpenter, National Parts Depot, etc...
As far as bodywork; since I'm not in the auto industry, I'd suggest using the best bed you have. Drilling the holes for trim is quick and easy, it's the rust repair that's going to cost you the most in the long term.
Old Dec 6, 2020 | 11:21 AM
Lrrr-RulerOfOmicronP's Avatar
Holes are not a big deal. Mask off the bed where the molding is mounted then tap the molding on and get it aligned. Then make sure it looks right from different angles. Once you have gotten the molding location where you want trace out the molding on the tape you put down. Now drill holes in the center of your molding lines. You can use your old bed to determine how many clips you need per molding.
Put a little primmer in the drilled holes to keep the bare metal from rusting.
It can be time consuming to get molding aligned perfectly but it's not too hard.
Old Dec 6, 2020 | 02:18 PM
josht's Avatar
josht
Hell, on these I don't think its even that difficult. Maybe if you have the lower body molding, but for the hump just measure out the holes from the old bed and drill them centered on the hump of the new bed. Just my thoughts looking at it. I'm not a body man and haven't done it myself, so take it for what its worth to ya.
Old Dec 7, 2020 | 06:47 AM
rwilly1's Avatar
rwilly1
Thanks for the replies.
I think my bed is too far gone.
I’ll keep an eye open for a replacement.
Old Dec 8, 2020 | 12:52 AM
GaryKip's Avatar
GaryKip
Tabco-Parts sells the bed floor, if that is what is rusted out.
Roelito78
15
Oct 8, 2023 03:11 PM
Redneck1465
Jun 5, 2010 11:44 PM
Lock
Jul 24, 2009 05:56 PM
nsuecondoc
Apr 22, 2008 06:25 PM
chieff
Jan 29, 2001 07:20 AM
