side trip repops for a '64
Old Apr 21, 2008 | 07:58 PM
nsuecondoc's Avatar
nsuecondoc
I found a '64 that originally had the side trim from the factory but it is missing now. Is anyone making new original repops?
Old Apr 21, 2008 | 09:53 PM
gritsngumbo's Avatar
gritsngumbo
I'll be as gentle as I can. NO! You'll just have to look, look and look some more. I looked for the missing cowl pieces for my 64 for over two years. Finally found them last month. FYI: This trim was only used on the 63 and 64 F100s so not enough of a customer base to justify repops for trim and many other pieces (That's why we call this year the Red Headed Step Child).
Old Apr 22, 2008 | 03:02 AM
camperspecial65's Avatar
camperspecial65
this trim is tough to find....it can be even more difficult depending on the body style you have as there was 3 different bed/side versions depending on the body type...1 for the unibody, 2nd one for the 64-6 type styleside bed in both long and shortbox form...same with the unibodys btw... and lastly the 4X4 styleside bothe 57-60 type box) also in long and short bed versions....the only parts that are the same on all 3 body types is the 2 hood pieces, cowl, and I believe door...but will double check to be certain. The rear cab corner pieces is the same on the 2 models that use it though.
If you add up just the bedside trim, both sides for all 3 body types...thats 12 pieces of trim....
- cs65
Old Apr 22, 2008 | 10:49 AM
nsuecondoc's Avatar
nsuecondoc
So..., between the lines I am feeling, if the truck doesn't come with it already don't buy it...
Old Apr 22, 2008 | 11:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by camperspecial65
this trim is tough to find....it can be even more difficult depending on the body style you have as there was 3 different bed/side versions depending on the body type...1 for the unibody, 2nd one for the 64-6 type styleside bed in both long and shortbox form...same with the unibodys btw... and lastly the 4X4 styleside bothe 57-60 type box) also in long and short bed versions....the only parts that are the same on all 3 body types is the 2 hood pieces, cowl, and I believe door...but will double check to be certain. The rear cab corner pieces is the same on the 2 models that use it though.If you add up just the bedside trim, both sides for all 3 body types...thats 12 pieces of trim....- cs65
The four hood side mouldings * are the same for all 1963/64's, as are the door and cowl mouldings.
There are two different cab corner mouldings, not one.
C3TZ-81423A16-A R/S / C3TZ-81423A17-A L/S ~ Use with 120" wheelbase
C4TZ-81423A16-A R/S / C4TZ-81423A17-A L/S ~ Use with 114" or 128" wheelbase.
* There are four hood mouldings because the hood side emblem bisects them.
The rear mouldings on the hood are 1.60" long (C3TZ-16722-A R/S / C3TZ-16723-A L/S).
btw: These moulding did not come with the Custom Cab package, they were an option on all models. Because of that, you may see a Standard Cab with the side mouldings.
Old Apr 22, 2008 | 02:56 PM
camperspecial65
Yeah...I know theres 4 hood moldings...I used to have a fully trimmed out 64 CC California truck...I still have one of the tiny hood mldgs kicking around....somewhere...
As for the cab corners...I thought there was basicly one mldg(2 pieces L&R) as the unibody doesnt have this molding since from the door back its the bedside mldg...
I also have a hood spear too...LH side...black stripe though...but straight as day one.
I may have to go wrecking yard hunting as I know these moldings are very hard to find...in any condition...whats the skinny on the clips ND...they the same as car stuff anywhere or ???
- cs65
Old Apr 22, 2008 | 06:25 PM
NumberDummy
As for the cab corners...I thought there was basicly one mldg(2 pieces L&R) as the unibody doesnt have this molding since from the door back its the bedside mldg...I may have to go wrecking yard hunting as I know these moldings are very hard to find...in any condition...whats the skinny on the clips ND...they the same as car stuff anywhere or ???- cs65
The clips are the same as 1963 Galaxies use, and are available from dearbornclassics.com
