IPR test - is this valid?
Old Dec 10, 2020 | 04:49 PM
countrycar's Avatar
countrycar
Chris/CJCOCN, just Checking in to see if you've made any headway. .
Old Dec 10, 2020 | 04:59 PM
cjcocn's Avatar
cjcocn
I’ve started testing as per the FSM and found out that I am not getting the required 5 volts at the CPS or anywhere else that I’ve checked.
I moved on to some PCM tests, but require some back probes to complete the steps outlined in the manual.
Ordered some back probes and in the interim I am using a test light to find out which circuits are shorting.
Im sure there are at least two shorts so I am going to continue tomorrow morning.
I’ll post up my progress and will also post the fix once I get there.
cheers
Old Dec 11, 2020 | 01:15 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
This ICP Duty Cycle not changing while starting is a loud clue but me no savvy. PCM will normally increase DC in attempt to start. Any chance you have another PCM to swap in?
Also to confirm; you pulled the WIF/Heater plug from back of fuel bowl, left it off? Fuses related to it good? Cigar lighter works?
Old Dec 11, 2020 | 09:14 AM
cjcocn's Avatar
cjcocn
I thought I responded to this earlier but maybe I didn't hit the post button!
No other PCM to swap in. This town is too small to have any spares floating around.
I pulled the heater plug from the fuel bowl and left it off. All fuses are good. Cigarette lighter and power point both work.
cheers
LCA078
Dec 29, 2018 08:42 AM
osricmason
6.4L Power Stroke Diesel
May 21, 2015 02:04 PM
richdawg
Sep 24, 2010 10:42 PM
matty169
Mar 15, 2009 05:24 PM
