Quick radiator replacement help
Old Dec 3, 2020 | 03:40 AM
Jbone405's Avatar
Jbone405
I have a 76 f250 4x4 c6 that we use on the ranch with a feeder on it. It does a lot of slow driving/idling dumping feed bunks during winter and driving through pastures in summer. I have a pinhole leak in my radiator. I can’t take this one off to get fixed as it can’t be down that long and it might not be worth fixing anyway.
I found some aluminum radiators on Amazon for not too much. But I don’t know if I want to go to aluminum.
Amazon Amazon
Anybody’s have anything better?
Old Dec 3, 2020 | 04:35 AM
i-w's Avatar
i-w
seems like a lot of people have used the Champion Radiators and have had good success.
not sure if you have the room BUT for what your doing i would look in to the 4 Row radiator not 2 row.
need to know if the radiator is a grill side mount or engine side mount.
https://www.championradiators.com/Fo...ator-1968-1977
more links
https://shop.championcooling.com/Per...Radiators/Ford
seen them all over ebay as well as Amazon.
Old Dec 3, 2020 | 08:18 AM
Tedster9's Avatar
Tedster9
The Champion are a pretty solid choice for not too much money. I don't particularly like the radiator caps they include with the radiator they seem real cheap. Aluminum radiators are said by some shops to need a separate bonding wire or strap to a good solid ground to prevent damage. Not sure why exactly but I'll take their word for it.
Old Dec 3, 2020 | 09:34 AM
Jetfixer-6's Avatar
Jetfixer-6
X3 on the Champion radiator. Do a search on this forum and you'll have all the info you need. As far as grounding, I can confirm at least for those of us in the drier climates that the lack of grounding the radiator to the frame can result in electrolysis. I had countless tiny holes in my nearly new Griffin. When I took it in to try to get it fixed they pressurized it in a large tank of water and called me over to have a look, hundreds of tiny bubbles throughout the entire core. Electrostatic discharge due to the very dry air passing over/through it. They also said using rubber isolators to mount the radiator contributes greatly toward this effect. So I would ground it if you can just as a precaution.
Old Dec 3, 2020 | 12:06 PM
Tedster9's Avatar
Tedster9
Huh. "Tiny Bubbles" worked out pretty good for Don Ho, but that ain't what we want in our radiators. Thanks for 'splainin' that.
Old Dec 4, 2020 | 09:13 AM
Jbone405's Avatar
Jbone405
Good info. I didn’t see any champions in stock but I feel more comfortable buying a aluminum radiator.
I’m kinda looking at something like this since I never really get much engine speed and it gets over 100 and humid here in the summer
Amazon Amazon
Mearntain
16
Jun 17, 2019 09:07 AM
Adam Woolridge
30
Jun 7, 2019 02:19 PM
BigBlue2
Oct 23, 2016 08:22 PM
HeatGeek
16
Jan 26, 2015 10:24 PM
cemenacho
Apr 9, 2006 06:42 PM
