Radiator has a leak
Old Apr 6, 2006 | 10:37 PM
cemenacho's Avatar
cemenacho
Radiator has a leak
Hi guys, I have a 1985 6.9L original radiator seems to have a leak somewhere on the top passenger side. any suggestions as to what I should do? buy a replacement, have the original one 're-done', or any other suggestions are welcome. also, how much am I going ot have to spend?
Old Apr 7, 2006 | 09:07 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
A new radiator will run $350-450. You can have yours rebuilt for substantially less than that....at least around here you can. Dunno about getting it done in NY.
Old Apr 7, 2006 | 09:55 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I would say find a radiator shop close to you and get an estimate.
But I will also say with the amount of salt the highway department uses during NY winters you probably need it recored which is still less than new by a long shot here in WV.
Old Apr 8, 2006 | 06:44 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
For a tempoary fix you can get liquid solder which I have used on occason. This will work on a very small drip nothing major.
Old Apr 8, 2006 | 09:56 PM
shimonmor's Avatar
shimonmor
It's probably the upper cap coming undone from the middle core section. That radiator served you well for twenty years. Put it out to pasture and get a new one. If you get it fixed you will soon develop leaks in other places. I got a new one that looks as good as the old one for $375. It's an easy swap...only bad part is draining the coolant...never a pretty evolution.
Old Apr 8, 2006 | 11:12 PM
cemenacho's Avatar
cemenacho
where do you get that stuff? who makes it?
Old Apr 9, 2006 | 03:55 PM
bigredtruckmi
Veteran: Navy
I get mine from a local auto parts store (napa). This one has more than a normal one because we are in a farming area. Also check with a TSC store if you have one in the area.
Old Apr 9, 2006 | 05:49 PM
bigredtruckmi
Veteran: Navy
Just found the web site of the product I use. http://jbweld.net/products/permoseal.php
Old Apr 9, 2006 | 06:42 PM
Chevy_Eater's Avatar
Chevy_Eater
Parching radiators really should only be done as a very temporary fix, just to buy a little time to get it fixed properly or replaced. Otherwise you are asking to be stuck on the side of the road on a hot day.
When the radiator in my '84 went it cracked the tank at the seam, couldn't be repaired. New one cost $400, that sucks, but the big trucks cost big bucks and so do the repairs.
