Couple Questions
Old Dec 2, 2020 | 10:43 AM
Sarge261's Avatar
Sarge261
Couple Questions
Hey Guys,
Im working on a 2000 7.3 I restored for a customer, some of you followed along. Im working on some punch list items and I have a couple questions:
I know some of you guys used a 6.0 or 6.4 starter to spin the beast over faster which one is best or is there a better alternative?
Is there someone that makes a plug and play fog light add on kit using OEM stuff, I thought I saw it somewhere and now I'm drawing a blank.
Thanks for the help as usual!
Sarge
Old Dec 2, 2020 | 11:00 AM
FordTruckNoob's Avatar
FordTruckNoob
Get a genuine Denso starter. Can't help you with the fog light kit, sorry.
Old Dec 2, 2020 | 11:26 AM
url's Avatar
url
Baja makes some:
https://www.bajadesigns.com/products...ocket-Kits.asp
Old Dec 3, 2020 | 07:34 AM
Listor's Avatar
Listor
i used a rough country kit and was able to tap/ splice into my existing fog light switch
not sure if any will use existing plug and play harness
Old Dec 3, 2020 | 11:11 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Denso starter if the customer is willing to pay for what they get. I installed one a while back and it is a great starter. I used longer mounting bolts (40mm) when installing the starter in order to maintain a secure fit since the Denso has a much larger mounting surface.
More details can be found in this recent thread: https://www.ford-trucks.com/forums/1...l#post19599014
I also created a video shortly after installing the Denso of how fast it cranks the engine, it is below.
As you may see in the thread linked above, Mitsubishi also offers a nice starter. My application was best suited for a Denso, but perhaps your customer does not fit the same application.
A/Ox4
S. California Chapter
May 21, 2019 02:48 PM
99hosss
Jul 22, 2012 03:01 AM
deemac
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Apr 30, 2008 12:45 PM
