Super duty mirror spot light
Old Dec 1, 2020 | 03:24 PM
Crotchety Ford truck only's Avatar
Wondering the difference between factory side mirror spot lights and "Recon" mirror spots. Knowing wattage of different bulbs might help. I think Recon is led, and my truck is not, or maybe the spot is, as it's in a sealed throw away unit.
I tried the smoked lens Recon unit and the spots barely came through (tried at night too). If it's not a lot more I wouldn't even bother, stock is quite lame.
I imagine you can only fit so much horsepower into that small unit, it's a great idea thou.
Old Dec 2, 2020 | 12:50 PM
Lin19687's Avatar
Lin19687
Active Streak: 30 Days
Active Streak: 60 Days
I don't have LED and the side spots are a joke really. Plus it only works when you are stopped. If I'm looking for a lost kid or dog I want to be able to drive slow with the spot light on !
You Might see if running a wire to battery or another fuse with a higher output is available
Old Dec 2, 2020 | 01:47 PM
BOSS 379's Avatar
BOSS 379
My factory mirror spotlights are LED and stay on up to a certain speed. Manual indicates threshold is 6 MPH.
Old Dec 2, 2020 | 02:43 PM
I defeated the speed function of the mirror spots so they can be on anytime. Just wanted more lumens. I don't feel "Recons" going to get me appreciably more. If there's nothing out there that will give me a lot more I'll be satisfied with that. I know I'll have to go another approach if it's that important to me.
Old Dec 2, 2020 | 02:49 PM
ford390gashog's Avatar
ford390gashog
The recons are brighter, in your post you said you tried the smoked ones?
Old Dec 2, 2020 | 02:51 PM
They are lame huh......................... Look at the trouble they took to do it, each have their own switch, module function, beautiful placement, it's all there, everything's done, except brilliance.
Old Dec 2, 2020 | 02:59 PM
I put one side on and waited till dark to see if I wanted to do the other. It hardly came through the tint (I'm not exaggerating "hardly").
I talked to tech support @ Recon and he said the clear might be 25% brighter, this was his opinion and they had no info on lumen rating for stock or theirs.
Old Dec 2, 2020 | 03:00 PM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
Cool
How did you defeat the "Speed Function" - is that available in FORScan? If "Yes", where - I never noticed it scanning through the spreadsheets!!! Thanks Crotchety!
Old Dec 2, 2020 | 03:03 PM
ford390gashog
Move one wire on the module.
Old Dec 2, 2020 | 03:05 PM
There's a good video on you tube. It involves a single jumper wire from one terminal to another to feed 12v on (always) to feed light circuit.
Old Dec 2, 2020 | 03:23 PM
jimd1050's Avatar
jimd1050
Awesome, thank you!!!
Old Dec 2, 2020 | 03:24 PM
Chris 86's Avatar
Chris 86
Did you also cut the grey wire?
Old Dec 2, 2020 | 03:49 PM
ford390gashog
Cut the grey wire and loop the end to the 12v constant in the harness.
Old Dec 3, 2020 | 05:44 PM
I did not.
Old Dec 4, 2020 | 02:22 AM
Bootlegfab's Avatar
Bootlegfab
If you want a plug and play solution to defeat the speed limitation...BoostedGreyGoose Designs makes a little harness that plugs right inline with the factory harness. I went that route out of sheer laziness and have been happy with it.
