Emergency brake replacement question
Old Dec 1, 2020 | 09:35 AM
78Custom302's Avatar
78Custom302
I have replaced the e-brake cables at each rear wheel and I'm wondering if I should replace the cable from the pedal back. It seems to be working fine, but thought maybe I should since I am replacing everything else. My question is, what is the procedure for doing that? Is it a difficult job?
Old Dec 1, 2020 | 10:24 AM
Meridian_Mike's Avatar
Meridian_Mike
It shouldn't be too hard.
The hardest part might be getting the new cable fished back up inside the cab and attaching the E brake pedal.
Do you have any old parts to look at? OR was it all already gone on your truck?
Old Dec 1, 2020 | 10:33 AM
78Custom302
The original is still there--just don't know if I should/need to replace. Just thought I should since I am adding all new brake components.
Old Dec 1, 2020 | 10:41 AM
Meridian_Mike
Check the cables to see if the rust has taken a toll on them.
If they are solid, keep 'em. If they are looking frayed, get 'em off there!
My front cable broke. The 2 rear cables that go into the drums look good (they are in a sheath). I am going to clean and inspect them before I put them into use.
Old Dec 1, 2020 | 11:17 AM
78Custom302
Got it. Thanks!
Old Dec 1, 2020 | 11:54 AM
John89's Avatar
John89
It's not too bad of a job. Hardest part for me was getting the pedal out and back in after hooking up the new cable. There are 2 nuts that are a good arms length away inside the engine bay.
While the pedal is out, be sure to clean out the fresh air vent in the driver's side.
Old Dec 1, 2020 | 12:45 PM
Jetfixer-6's Avatar
Jetfixer-6
And change the floor grommet for the cable
https://www.steelerubber.com/firewal...met-20-0760-24
Old Dec 1, 2020 | 01:40 PM
78Custom302
Did you get to them from below? I don't think they're accessible from inside the engine bay on my truck.
Old Dec 7, 2020 | 04:34 PM
78Custom302
Thanks for the link
Old Dec 7, 2020 | 04:52 PM
cwegga's Avatar
cwegga
On mine they are in the wheel well. I need to undo the plastic fender liner and go the previously stated arm deep in the wheel well to reach them where they come through the firewall.
Old Dec 7, 2020 | 04:57 PM
John89's Avatar
John89
Sorry, the nuts are located behind the splash liner of the wheel well.
Old Dec 8, 2020 | 10:32 AM
78Custom302
Got it. I did look into it the other day and found those two nuts. It doesn't look like too big of a job. Thanks
Old Dec 8, 2020 | 10:46 AM
meangreen92's Avatar
meangreen92
It all swapped over pretty easily when I changed cabs, but I don't think that I separated the cable from the pedal assembly.
X2 on cleaning the fresh air vent if you have one. There will never be a better time, since the pedal assembly blocks access to the vent and most of its fasteners.
78Custom302
Nov 7, 2020 09:37 AM
TchTchr
Jun 27, 2013 09:04 AM
Buyerz
Aug 17, 2012 07:41 PM
Dave S
Aug 19, 2008 04:18 PM
ronquillaw
Jul 7, 2008 11:07 PM
