302 Identification
Old Nov 30, 2020 | 09:57 PM
_Duke_'s Avatar
_Duke_
4wd Low
302 Identification
Hello, I recently picked up a C80E-6015A 302 block bored .030 over with a pair of its original heads. So far I know it’s a 68 block.
Planning to build and place it into my 62 Flareside which has a 223. I’m curious as to what these heads are (# C80E-J), and if they have any potential.
As seen in the pictures they have a brass nozzle going into the exhaust ports. What were they for?
This is my first time building
a Windsor Ford so any pointers would be nice.
Thank you
Old Nov 30, 2020 | 11:38 PM
Conanski's Avatar
Conanski
Looks like they have the larger open chambers so they are nothing special. The brass plugs are where the air into the head smog system connected, those big nozzles in the ports won't help airflow. The pressed in rocker studs are another weak point, they tend to pull out with heavier springs and high lift cams. Overall you could substitute late model E7TE heads and fix the problems with these and not lose any performance, or if you were to find a set of GT40s you would fix everything and gain performance potential.
Chambers: 63cc
Valves: 1.78"/1.45"
Valve seats: Not hardened
Rockers: Rail type with pressed in studs.
Old Nov 30, 2020 | 11:41 PM
_Duke_'s Avatar
_Duke_
4wd Low
Originally Posted by Conanski
Looks like they have the larger open chambers so they are nothing special. The brass plugs are where the air into the head smog system connected, those big nozzles in the ports won't help anything. The pressed in rocker studs are another weak point, they tend to pull out with heavier springs and high lift cams. Overall you could substitute late model E7TE heads and fix the problems with these and not lose any performance, or if you were to find a set of GT40s you would fix everything and gain performance potential.
Chambers: 63cc
Valves: 1.78"/1.45"
Thank you, I’ll look into some new heads with hardened seats then.
Old Dec 3, 2020 | 10:01 PM
baddad457's Avatar
baddad457
Chambers: 63cc
Valves: 1.78"/1.45"
Ditto. Someone has replaced the two piece spring retainers with one piece, that's the only plus here.
Old Dec 3, 2020 | 10:07 PM
_Duke_'s Avatar
_Duke_
4wd Low
Would you know If I would need to get different sized pushrods with various heads, or do they share similar geometry?
Old Dec 3, 2020 | 10:13 PM
baddad457's Avatar
baddad457
Possibly, but I think the E7's used the same length pushrods as the 68 motors. Those rail rockers won't do you any favors either.
Old Dec 3, 2020 | 10:20 PM
_Duke_'s Avatar
_Duke_
4wd Low
Thank you, I’ll look into a set of E7s if they won’t require the rods then. 👍
Old Dec 4, 2020 | 08:00 AM
baddad457's Avatar
baddad457
Or find a set of GT40 heads (not the "P") heads. Or any set of reasonably priced after market heads. If you do get a set of E7's, get a porting bit and remove the Thermactor bumps from inside the exhaust port roofs before bolting them on. I would also open up the walls and port opening (top only) to match the header gasket. This operation takes a couple hours at most and does wonders for the exhaust flow.
reamer
Jul 21, 2020 10:03 AM
TMI
Nov 18, 2018 10:02 PM
TMI
Apr 26, 2017 07:08 AM
crazy96863
Apr 15, 2013 08:57 AM
Sparx Macgyver
S. California Chapter
27
Jul 27, 2010 07:39 PM
