Highboy rear leaf spring upgrade
Some of the springs I considered:
- 99-07 SD rear springs
- Cheap for aftermarket pro comp lift springs.
- Not sold on pro comp spring quality.
- Most 99-07 SDs weigh more than my truck so I will give up ride quality.
- Would be able to handle any load I would throw at it.
- Finding good used ones is a challenge as the trucks are all older
- 08-20 SD leaf springs (18-20 are suppose to ride the best)
- Can get a good used set for a decent price.
- Springs are loooong which could add more fab work
- Can handle any load I throw at them but I give up some ride as most SD are heavier than my truck.
- Pro comp sells lift springs that are reasonable
- 09-14 f150 leaf springs
- Long and soft
- Finding good used ones can be hard
- F150 weight and load rating pretty equivalent to my highboy
- Wheel hope will probably be a problem
- May need air bag if I have heavy loads
- Can buy after market raptor springs if I want to burn some cash
- 15-20 f150 leaf spring
- Main difference between these and the generation before is they are shorter on the forward fwd end.
- Easier to get a low milage set used
I set the truck on the springs to get an idea of lift block height I will need. I was a little nervous doing this and probably only had the springs compressed for a minute or less. This should be the equivalent of having 300-400 lbs in the bed over the axles.
I am thinking about add air springs with daystar cradles so the airbags won't cause a problem if I am off-roading.
Don't know when I am going to have a chance to get started but hopefully will be done by spring. I think I could have it done in a couple weekends if I don't run into any problems but I doubt that will happen.
Clever idea to compress the springs under the truck. No way you're going to hurt them that I can think of. Other than the weight of the axle and tires, that's the load they're going to be carrying the rest of their life anyway. And you can easily load more in the bed than the weight of one axle and a pair of tires.
If you're rarely going to carry anything, you could even hold off on the bags. But I'd do the same thing as you're planning, and do it all at once while you have the tools out and the mindset to make things work. Can't hurt to have the additional capacity at your disposal for that time when you decide to offer your services to carry fire wood home from the hinterlands!
Can't wait to see the next update.
Paul
Similar to the 63" cheby springs I put in mine. I used a 2+1 leaf which was lightest option, and just happened to be what I could find easy. Can easily gets 3+1, 4+1 for cheap or high quality high leaf count lift springs.
Do you have axle wrap and wheel hop issues now?
Paul
I have noticed a little wheel hop sometimes. I assumed long soft springs could give me trouble so I got a traction bar kit from ruff stuff when they had a sale.
I was considering a 14 bolt but could not find one with less than 200k for a decent price. My old jeep has a dana 60 rear out of a dodge that was rebuilt with a detroit locker making spending money on a 14 bolt hard.
So I pulled the dana 60 out of the jeep. It is only a 30 spline so it really was not tough enough if I ever do put the j10 back together.
checked the guts to make sure everything inside was still good.
I have a lot of garb to cut off the diff but using the 60 should allow the rear driveshaft length to stay the same.
I got the spring hangers mounted. I got spring mount measurements from my neighbor's truck to verify the f150 builders pdfs were acute. Between the f150 builder pdf and the f250 dim pdfs I was able to align the new spring hangers pretty easily.
I did have to clearance the bed support for the shackle to clear.
lift blocks ended up taller than I expected. I was planning on a 4" and ended up with 6-1/2" so the u-bolts I ordered were too short. I also had to offset the the lift block 1/2" to move the diff forward since the springs are more angled than the old ones. The bump stops worked out pretty well. I was able to bolt on some super duty bump stops I had and fit a piece of pipe for the stop. I have it set up for 3" of up travel plus whatever the stop gives.
Block height won't matter with 'Ruff traction bar. It will change anti-squat properties but you can likely make it quite flat to minimize lift under throttle.
As smoky diesel brought up the traction bar, using a traction device like that would also lower the stress on the bolts I would think? Not really sure, but it feels to me like that would be the case.
Paul
I also already have the kit to build a track bar and an air bag load assist kit. I have toyed with the idea of removing 1 to 1-1/2" out of the lift blocks and adding the height back with pressure in the air bags. I think I should drive it at the current spring rate before I add more spring rate to it though.
F150 mounts the shocks on the outside of the springs so in tried to overkill the mounts since the shock has so much leverage on the mount. Keeping the shocks inside the frame was going to get tight with the track bar and moving them farther out on the rearend should increase there effectiveness. The f150 shocks also have a lot more travel than the original shocks. The shock angle is about 30 degrees.
Ran out of welding wire which slowed me down.
Building shock mounts
Shock mount and shock mounted on frame.
Air bags mounted to frame. I still need to get the lower air bag mounts done but I ran out of welding wire.
https://www.pmfsuspension.com/Ford-F...ocks_p_42.html
Sorry I didn't see you were going to add tabs for the ubolts.
