Brought a new truck (20' F-450 6.7) home late Wednesday and changes headlight bulbs. I needed to remove the factory air box & tube to reach the passenger side bulbs. I also installed Amp Research power steps. After finishing everything up I drove the truck about 100' feet to a second garage. probably ran for 1 minute. I noticed that the check engine light was on and looked at the codes, I have the following showing:
P00C7, P00F3, U060F, U068B, Catlyst, Htd Cat, 02Htr, Misfire, Fuel, Comp, SEc Air, 02 sensor, ERG. When I try to erase get a "No Link" on the reader. I looked under the hood and I had forgot to reattach the electrical connector to tube.
Are the codes from forgetting the air box tube connector? It seems like that is what causing the codes. I was hoping the scanner would clear them. My scanner is from 2005, I have a newer scanner but its not accessible today. Thanks for any advice.
My guess is the codes will probably disappear after you drive it a bit with the connector plugged in. Could also maybe disconnect the battery to see if that resets the codes.
Thanks for replying, I was able clear the codes with a current scanner. All good now.
