Check engine light on no codes
Old Oct 8, 2020 | 07:26 PM
Excurvelle's Avatar
Excurvelle
While pulling a mountain today with the camper in tow the lower hot side tube popped loose, I had to find a place to stop. I reattached the boot, got to the campsite and tried to clear the codes with my Scangauge II. No codes. Did it store a different type code and if so will it clear on its own?
Old Oct 8, 2020 | 07:44 PM
AK4x4's Avatar
AK4x4
I would check for codes using Forscan. Good Luck, Russ
Old Oct 9, 2020 | 05:22 AM
Yahiko's Avatar
Yahiko
The SGII is known for not being that good with reading or clearing codes.
You want something with a little better track record when it comes to codes.
Forscan or one of the high end scan tools are your best pick.
Old Oct 9, 2020 | 09:41 PM
Excurvelle's Avatar
Excurvelle
I have ForScan on my laptop at home 100 miles away, unfortunately only the Scangauge2 is with me, at the campground. Didn't drive it much today, tomorrow we will be out and about. Was going to pick up a intercooler boot but no dealers had them in stock.
Old Oct 9, 2020 | 09:58 PM
Theboneskes's Avatar
Theboneskes
Your best bet is to get home and get a different set of hot side hoses and new clamps. I got mine from Riff Raff and love them. Have had continuous 23 to 26 pounds of boost on them without an issue when pulling big hills.
Clean off the oil REALLY well with brake cleaner and some rags of the boots and pipes/connections and limp it home, then get new clamps and boots, clean everything and you wont have an issue again.
Old Oct 10, 2020 | 09:39 AM
Excurvelle's Avatar
Excurvelle
That is the plan. Going out today to find an auto parts store to get brake cleaner. Wife has hair spray. Very poor internet connection here (3G) so I can't order the boots. Fortunately the trip home is mainly downhill but today unloaded we will be pulling grades.
Old Oct 11, 2020 | 01:32 PM
Excurvelle's Avatar
Excurvelle
Pulled the camper home, no problems, was a nasty trip pouring rain. Once I unhook and get stuff settled I will hook up Forscan and see what code was thrown.
Old Oct 11, 2020 | 02:46 PM
Excurvelle's Avatar
Excurvelle
If interested...Cleared codes. FYI P2262-E0 and P2262-C Turbo boost not detected. Gotta love ForScan!
BearFootCustom
Oct 20, 2010 10:44 AM
woodduck17
Jul 29, 2009 10:48 AM
hondaracer27
May 11, 2009 04:25 AM
dougf2504x4
Feb 22, 2009 08:49 AM
HENDEL JR
Jan 8, 2006 12:45 PM
