Injector Timing
Old Nov 25, 2020 | 10:55 AM
abitterman's Avatar
abitterman
Question Injector Timing
Hello all! I have been using this site for a few months now and have found you all to be a great help in solving a couple of problems that I have had with my 04 6.0. However, I haven't been able to find any information regarding Injector Timing. I have been using the Torque App on my phone to monitor the different pids for this engine. The pid in question is the INJTOP which I believe is Injector timing?? when driving it reads between 0 and around +5. when coming to a stop (idling) the gage runs up to over a thousand then back to normal when i start driving again. this happens every time. I see no changes in the other pids or feel of the engine. Could this just be a Torque App glitch or could there be an Issue that I'm not seeing? I appreciate your thoughts.
Old Nov 25, 2020 | 11:35 AM
Visurveyor's Avatar
Visurveyor
I'll look at my torque and see the pid your talking about? Your injectors are fired by your Ficm and it takes its info from your Ipc and regulates it with the ipr Not sure if that pid your looking at is for the 6.0.
Gassers are different.
Thought. Is the pid highlighted in green when you selected it?
Old Nov 25, 2020 | 01:42 PM
abitterman's Avatar
abitterman
Yes, it is one of the Green Pids. Thanks for checking.
Old Dec 22, 2020 | 06:49 PM
abitterman's Avatar
abitterman
I still haven't come up with an answer for this. Does anyone have an Idea of why the timing would read this high? Also, on occasion when I slow to an Idle (only when at normal running temp) the engine runs rough and I get a P0275 contribution code. Again the only parameter that is out of whack seems to be the InjTop. I doubt that has anything to do with it but I'm throwing it out there for comment.
Old Dec 22, 2020 | 07:02 PM
Visurveyor's Avatar
Visurveyor
I'll fire mine up tomorrow and add pid to my screen and see what it reads.
Does it effect the operation or running of motor, or something you just spotted and wonder why?
Old Dec 23, 2020 | 01:57 PM
abitterman's Avatar
abitterman
It doesn't seem to effect it at all but it does start doing that when the engine starts to worm up. I believe the #5 contribution issue is not related but won't bet my life on it.
Old Dec 23, 2020 | 03:07 PM
Visurveyor's Avatar
Visurveyor
O.k. here's what my truck reads.
1023. 1° at idle
3.2° around 1200 rpms
6.8° at 2000rpm
The 1023.1° at idle has me a little stumped to. But as soon as I hit throttle it goes to single digits. Maybe someone else has insight as to why its like that. Now I have not used Forscan on it yet, but will. I used Torque Pro.
Old Dec 23, 2020 | 07:06 PM
abitterman's Avatar
abitterman
I'm guessing that it is some kind of glitch with Torque since we have basically the same numbers.
Old Dec 23, 2020 | 07:16 PM
Visurveyor's Avatar
Visurveyor
I still want to see what Forscan says. Just curious.
I'll do it in the morning and post.
Old Dec 23, 2020 | 07:19 PM
abitterman's Avatar
abitterman
Sounds good.
Old Dec 24, 2020 | 01:02 PM
Visurveyor's Avatar
Visurveyor
First pic is Forscan at idle(643 rpm's)
Second is Forscan at 2000 rpm's
Third is Torque Pro at 2000 rpm's
Fourth is Torque Pro readings that I monitor daily (at idle)
as you can see there are big differences in readings between the 2 apps. I still got the 1023 at idle on Torque, but Forscan only 3.4, So not sure what to think about monitoring this pid. I trust Forscan on things like this more than Torque. The reason I use Torque for monitoring my daily drive, is optics. Easier to read on Torque. Hope this info helps you somehow.
Merry Christmas!!!
ddeflyer
20
Feb 13, 2015 08:29 AM
bduemig
May 5, 2013 01:13 AM
jarmbrester
Jan 22, 2009 02:35 PM
taisa899
Computer Chips & Tuners
Feb 8, 2007 12:37 AM
csramsey640
Jan 10, 2005 03:50 PM
