VR1
Old Nov 24, 2020 | 09:03 PM
Red60's Avatar
Red60
VR1
Does anyone else use Valvoline VR1 high zinc 20/50 in their classic?
Old Nov 25, 2020 | 09:24 AM
Tedster9's Avatar
Tedster9
I use the VR1 10w30, hot oil pressure in my motor is excellent. I'm of the opinion that unless the bearings are knocking, or pressure is very low, heavier viscosities aren't necessarily the best idea.
The only thing that gives me pause is they state "3 months or 3 thousand miles". Take that literally that would get a little spendy. The reason for this is because racing oil doesn't have all the level of detergents or dispersants that extended oil change intervals require. Makes sense, I guess. I've decided not to worry about it. So far so good.
Old Nov 25, 2020 | 10:08 AM
ford390gashog's Avatar
ford390gashog
I see no reason to use a 20w50 as thats a 30 point spread for oil shearing and it does not have a very high HTHS. The 10w30 actually stays in grade longer and has a better HTHS. I will say for the cost of the VR1 in 10w30 and looking at the add pack you would be at the same level running a 10w30 HDEO. The Ford requirements is still very high on Phosphorus and Zinc and it has a complete detergent package.
http://pqiamerica.com/HDEO_Sample_Summary_Dec_2016.html
A 10w30 HDEO is far above the VR1 protection capabilities
VR1 is actually not very impressive when you look at what you are getting.
Old Nov 25, 2020 | 01:36 PM
Red60's Avatar
Red60
I use Castrol GTX in my newer engines and the 01 Focus is topping 250,000 miles. Last time I had the covers off it was clean with a slight golden color on the aluminum.
Thus a far cry from the Pensoil engine I saw in the 80’s that only had room for the rocker arms it was sludged solid! What a pain to clean and rebuild that slimy crusty mess!!
84 f250 6.9
22
Mar 21, 2009 11:35 AM
rontj
Sep 5, 2007 10:38 AM
amw_drizz
1978 - 1996 Big Bronco
22
Mar 14, 2005 05:16 PM
canda250
Feb 2, 2004 09:20 AM
ecsmith0624
Oil & Lubrication
Jan 12, 2004 09:50 PM
