Master Cylinder
I just noticed some staining near my left front shock area. I have a 2002 F 250 and noticed the rail was stained. When there is foreign staining it's time to investigate. Anyway I traced it up to the Master Cylinder and it looks like it's coming from the lower port on the cylinder. I called Ford and the Master Cylinder is back ordered and runs $90, not a problem. I can wait until it gets here. So for those who have replaced their Brake Cylinders, is it a difficult process. What's a good way to do it? I'm beginning to research it now. I know bleeding it and getting all the air out is critical. So any thoughts or methods would be great.
Thanks,
PJ
Sometimes you can get away without needing to bleed the whole system if you pump the brakes before removing the old MC and bench bleeding the new one. You will have very little air in the lines and possible for the air to bubble back up once you install the new MC.
This is the procedure for a 2014 Super Duty with gas engine. Might give you some insight.
It's not a difficult job but make sure you have the appropriate size LINE WRENCH (do not use an open end wrench) and bench bleed the new MC before installing it. If you do not, you will regret all of the wasted time trying to bleed the brakes.
-- Dave
