Sponsored by: Kumho
Master Cylinder Bleeding
Old Aug 25, 2020 | 07:31 PM
moejr's Avatar
moejr
Do you need to remove the master cylinder from the vehicle to bleed it? Can I just follow the "bench bleed" instructions with the master mounted in place?
Old Aug 26, 2020 | 05:08 AM
JWA's Avatar
JWA
Bench bleeding while still mounted is the easier way---I don't know how I'd bleed one off the vehicle.
Old Aug 27, 2020 | 10:37 AM
moejr's Avatar
moejr
Bench bleeding is recommended before installing a master cylinder, clamp the master in a vise and bleed till no visible air bubbles, my master cylinder is mounted to the firewall so can't see the fluid reservoir, I'll have someone push the brake while looking for air bubbles. All my brakes components where replaced a few years ago but they are soft, even after bleeding the system a couple of times....... it might be that there's air trapped in the master cylinder.
Buckley
Aug 24, 2020 07:53 AM
Pappys53
Jul 22, 2020 08:41 AM
Tim Hodgson
1978 - 1996 Big Bronco
Jan 29, 2019 10:18 PM
dogg16
Bronco II
Sep 14, 2004 04:19 PM
