Headlight switch question
Old Nov 24, 2020 | 09:30 AM
ReForder's Avatar
ReForder
Originally Posted by Bob Ingram
The 6v switch will be ok for the long term. The limiting factor isn’t voltage as much as current. Since the current will be lower at 12v it will be fine.
That said, running all that current through any switch is not the best way to go. I installed headlight relays in my 48, one for low and one for high beams. The current through the switch is just a few ma.
^This is great advice, too. The headlight relays take the heavy work away from the switch itself, which doesn't necessarily allow all of the current to go through to the lights anyway, and off-loading that to the relays often produces a brighter light. The Galaxie also got this upgrade over the summer. The difference in lighting was night and day (no pun intended).
Old Nov 24, 2020 | 02:39 PM
Bob Ingram's Avatar
Bob Ingram
Originally Posted by avf100
Thanks Bob...thats what Ive read also so Im going to try my original switch.
And I put halogen lights in with relays so Im good there too
I wouldn’t recommend running halogen off of the light switch. They draw a lot of current.
I installed relays and circuit breakers on my 48 when I put the halogen bulbs in.
Old Nov 24, 2020 | 05:15 PM
52 Merc's Avatar
52 Merc
If you've done all that, I'd say you're golden.
Old Nov 24, 2020 | 05:45 PM
avf100's Avatar
avf100
Im not...im using relays
Old Nov 24, 2020 | 05:54 PM
Bob Ingram's Avatar
Bob Ingram
then the whole debate in the headlight switch is done, you only have a few ma running through the switch. You could use a micro toggle and be safe.
1low50
Oct 5, 2009 08:55 PM
EastTexasTruck
18
Feb 24, 2009 12:11 AM
knash0727
Sep 13, 2008 06:04 PM
orangeford
Mar 18, 2003 06:22 AM
