Mini Maxx
Old Nov 22, 2020 | 04:12 PM
UncleBuck18's Avatar
UncleBuck18
Mini Maxx
With the Mini Maxx can you use the tunes that come on it to delete the dpf and egr? Without having to add any other time to it, all I want to use the tuner for is to pretty much cancel all the codes
Old Nov 22, 2020 | 05:17 PM
T diesel's Avatar
T diesel
Give a hoot, don’t pollute.
Old Nov 23, 2020 | 06:45 AM
Desert Don's Avatar
Desert Don
As you can see, you are not getting a lot of response here. This forum is not what I would call “delete friendly”. You will likely need to look on some other forums to get the answers you want. Hopefully you won’t need to pass smog check for registration purposes.
Good luck.
Old Nov 23, 2020 | 08:07 AM
Just Strokin's Avatar
Just Strokin
More likely than not, stock tunes purchased as part of the tuners are for non-deleted trucks. It is illegal to sell tuners with delete tunes. You have to specifically buy them as an option or add ons.
Old Nov 23, 2020 | 09:35 AM
ford390gashog's Avatar
ford390gashog
When was the last time H&S was in business? Pretty sure its been at least seven years and anything out there is ancient.
Edit.
Yes they are long out of business http://www.trucktrend.com/how-to/eng...l-tuning-dead/
File Type: pdf
Old Nov 23, 2020 | 05:23 PM
Big T-Bone's Avatar
Big T-Bone
The minimaxx will allow you to cancel fault codes and it has the capability to run tunes with the DPF/DEF intact. It also has the ability to run fully deleted as well... I have had one since early 2011, on my 6.7L PSD and run it both ways.... Great tuner to bad they were put out of business... There are still sites where you can find a lot of info on the tuner and its capability you just have to look...
Old Nov 23, 2020 | 09:29 PM
jimmermd's Avatar
jimmermd
There are three sets of tunes on the mini maxx:
Tunes with emissions intact.
Tunes to run with dpf deleted.
Tunes with dpf deleted that will also disable your egr control.
partyman666
6.4L Power Stroke Diesel
Aug 22, 2020 11:03 AM
Zyoung200
Mar 5, 2020 09:47 PM
brada
Oct 2, 2017 07:57 PM
uh60
May 8, 2017 02:17 PM
GRoke7.3
6.7L Power Stroke Diesel
Aug 14, 2016 12:40 AM
