E150 ABS codes
Old Dec 8, 2020 | 03:09 AM
wwhite's Avatar
wwhite
I think you have one of these: E-series vans feature an optional Kelsey-Hayes EBC-5 4-wheel ABS system
View the thread here: 94-96 E-series 4-wheel ABS Codes - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old Dec 8, 2020 | 03:49 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by willem_at_work
Yes, but when i search for 2c286 then i get all kinds of parts. What i need is just the computer or control module
The HCU ( hydraulic control unit ) is what you are looking for if you have determined the wiring to and from it is good. The computer is a separate part. I tried looking it up on RockAuto and Cardone’s websites and neither one had a HCU for 4 wheel ABS.
Old Dec 8, 2020 | 06:03 AM
willem_at_work's Avatar
willem_at_work
you're kidding... that does not look like something that's easy to replace
Old Dec 8, 2020 | 02:36 PM
subford's Avatar
subford
The part number should be for the HCU: F4UZ 2C286-A.
Old Dec 8, 2020 | 04:24 PM
My4Fordtrucks
I’m not sure what you mean. What does how easy or difficult a repair is have to do with part availability? You could try sending a PM to NumberDummy to see if a dealer still has one on the shelf if you cannot find one from a parts store.
Old Dec 9, 2020 | 05:26 AM
willem_at_work
the control module would be an easy fix i think? This ECU looks like brake lines need to be bled and all that stuff
Old Dec 9, 2020 | 03:08 PM
My4Fordtrucks
Yes. Replacing the HCU will require bleeding the brakes since you are opening up the hydraulic system. I don’t think you need any special tools. I replaced the 4 wheel ABS HCU on my ‘94 Bronco and I didn’t need anything. Standard bleeding procedures.
Old May 17, 2022 | 07:58 AM
David Masch's Avatar
David Masch
Trailering
So i have the following error codes
C1198 OPEN/SHORT LF DUMP VALVE SOL
C1214 OPEN/SHORT RF INLET VALVE SOL
C1206 REAR INLET VALVE CKT FAILURE
When i check the internet for the meaning, it seems that all 3 can be related to a loss of signal due to a possible wiring issue. That would be great, because i also have the problem that the speedo jumps around at high speeds (maybe bad signal?) , and i have a gearbox that sometimes wants to engage when the van is stopped (i read that the gearbox is controlled by a computer that reads the van's speed, so maybe this is a gearbox computer not knowing if the van is moving or not?).
Does anyone have a wiring diagram to this ABS system? maybe there is a spot where all 3 wires or signals come together, or maybe i just need to clean a connector?
Im having an issue finding the Orange/Black Data Link Wire..
Here is the wiring diagrams
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
TimothyOnline
50
Apr 1, 2026 12:29 PM
utahjd1
Aug 16, 2020 05:33 PM
Mo8414
Jan 8, 2019 05:40 PM
Ryansmurf
1978 - 1996 Big Bronco
Dec 7, 2016 02:11 PM
