Help.. ditching the fitech
Old Nov 21, 2020 | 05:27 PM
captainwoot's Avatar
captainwoot
Hello all.. I'm disappointed after a 4 year battle with myfitech system I'm about to give up. The problem I have a weiand 4bbl intake and my only carb on hand is my old 2150 2bbl. Can I make this work or am I setting myself up for more trouble? My engine is a fresh stock 400. I guess I need advise for the best smallish carb or someone with an idea to fix the corrupt tach signal my fitech sees even after new distributor and coil and icm.
thanks
Brent
Old Nov 21, 2020 | 05:31 PM
captainwoot
same truck.. fresh paint this year
Old Nov 21, 2020 | 05:35 PM
ford390gashog's Avatar
ford390gashog
My FiTech is also on the shelf. I personally like the Summit 600cfm carb with annular boosters. I ran that while waiting for the Holley Sniper to arrive. Its a hard to beat carb and there is plenty of people here using them.
Old Nov 21, 2020 | 06:00 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Get a quality 2bl to 4bbl adapter (a good one Like a Super Sucker, not a Mr Gasket cheap one with a massive gap to fill) and get with it.
HVH Products - Carb Spacers - Page 1 - High Velocity Heads
https://www.jegs.com/i/HVH/264/SS441...QaAkvFEALw_wcB
https://www.summitracing.com/search/...s?fr=part-type
https://pitstopusa.com/i-23956232-we...AaAh0VEALw_wcB
I heard that Fitech has a better Facebook tech page discussion forum than the Fitech site itself. This guy went Fitech maybe some help here?
https://www.ford-trucks.com/forums/1...n-77-f150.html
Maybe more help? https://www.ford-trucks.com/forums/1...injection.html
Old Nov 21, 2020 | 06:01 PM
85e150's Avatar
85e150
Amazon Amazon
Same thing, different listing:
https://pitstopusa.com/i-22956189-tr...-manifold.html
Serving suggestion.
Edit: Is there an echo in here?
Last edited by 85e150; Nov 21, 2020 at 06:07 PM. Reason: Beaten by 1 min in responding.....
Old Nov 21, 2020 | 06:03 PM
Christmas's Avatar
Christmas
Not sure how true this is but fuel injected carbs need a single plane manifold to work correctly.
Old Nov 21, 2020 | 06:10 PM
77&79F250's Avatar
77&79F250
I do not make recommendations from guessing.......... I make if from hard learned lessons. I had the exact same adapter it would not work with a 2150 without using a Ford OEM port/vacuum plate. In the end the 2bbl made the 302 gut less, compared to the 4bbl.
https://www.ford-trucks.com/forums/1...l#post17897779
85e150's Avatar
85e150
This would be more the case where you have port injection.
Throttle body injection has some of the same issues as a carb with respect to keeping the fuel in suspension after it leaves the throttle body.
Single or dual plane would be dictated by the other engine factors, or by money--I wouldn't spend money on a manifold until I worked at dialing in the carb or EFI on the manifold I already had on the engine.
Old Nov 21, 2020 | 06:11 PM
matt167's Avatar
matt167
2bbl on a 400 using a 2bbl adapter makes about as much sense as flushing $50 down the toilet IMO.
( Insert favorite 4bbl carb brand here ) will do just fine on a 400. A finely tuned quadrajet with it's correct adapter if needed would be a great carburator and could rival a TBI system. Some people hate them, but a Qjet is a great carb.
I'm an EFI person, and I'd install a better port EFI system
Old Nov 21, 2020 | 06:14 PM
85e150's Avatar
85e150
He has the 2bbl in hand. Adapter is less than $50. It's a stock 400, it will be fine with a 2bbl. It sure doesn't need a "Quadrabog" with those garbage can sized secondaries.
Old Nov 21, 2020 | 06:29 PM
captainwoot
This is my second fitech unit. First one the ecm died out of warranty. This one is only 6months old and ran great untl it decided to disslike my tach signal . I sourced a new motorcraft icm.and coil. Redid all wiring tried to shield the wiring etc.
I'm not totally new to the game I am a mechanic by trade..but I will admit my carb skills are really lacking now lol. I am waiting to see if I can return the fitech for exchange or refund . And adapt my 2150 in the interim. It is my daily so this really sucks!
Old Nov 21, 2020 | 06:33 PM
captainwoot
Are you running the sniper system now? Are you happy with it?
Old Nov 21, 2020 | 07:41 PM
1TonBasecamp's Avatar
1TonBasecamp
Single or dual plane would be dictated by the other engine factors...
It's all true. Or, in the immortal words of the famous Saturday Night Live skit... "It's a floor wax, AND a dessert topping!"
It's been well documented in many dyno tests that the typical throttle body injection systems from MSD, FiTech and Holley can benefit from at least an open plenum. If not strictly a single plane manifold, the open plenum helps the signal interpretation of the sensors. Or at least that's what they surmise.
So with a typical dual-plane like a Performer it is recommended to grind down the plenum divider slightly and use an open gasket, or just add an open spacer on top so the signals are taken as a combination of the left and right bank, rather than just one side.
I've never done it (yet) but have been reading about it since the beginning of the more recent introduction of the new-ish TBI systems. Did not come up with the old GM TBI setups from Turbo-City and others, and if I remember those manifolds used individual separated holes rather than any common plenum. But the new crop starting I think with the MSD Atomic and Edelbrock E-Street (no longer available) and then the FiTech seem to benefit from the open plenum.
Paul
Old Nov 21, 2020 | 09:33 PM
ford390gashog
I am on my third engine now with a Sniper, I had a issue with one TB that had a leaking injector, Holley sent me a replacement overnight and it has been fine. The ability to tune is leaps and bounds above the Fitch and is much more open source.
Old Nov 21, 2020 | 10:13 PM
rotating_equipment's Avatar
rotating_equipment
I've got a Sniper kit and it's been pretty solid for me. Been on the rig over a year but not too many miles on it. I'm quite happy with the whole setup - Hyperspark plus Sniper is fantastic.
