Winter Oil
Old Nov 21, 2020 | 07:39 AM
Colemater's Avatar
Colemater
Winter Oil
I have heard I should run “winter oil” I’m my 77 F150. 351M 4x4
is that true and if so what should I use
I live in Washington DC so can get to 0 F a couple times a year
anything else to consider in winter?
thanks in advance
Old Nov 21, 2020 | 09:07 AM
Tedster9's Avatar
Tedster9
10w30 was very likely recommended for year round use by Ford in your Operator's Manual. In extreme cold, extended operation below 0° on a continuous basis might want to look at something lighter. What viscosity do you normally run?
Other areas to look at - make sure the engine thermostat is the correct temperature rating. A 195° F. is not "too hot" and is what Ford spec'd, or near enough. Check that there is a 50/50 mix of antifreeze concentrate and water in the radiator for adequate freeze protection.
Make sure the battery, and charging system, is up to snuff. Heat is actually what kills car batteries, but it is the cold temperatures that exposes this defect, because it takes a whole lot more current to turn over an icy cold engine with thick, sludgy oil, and at the same time ability for the battery to supply current output is cut in half at low temperatures. It can take hours or days to fully charge a car battery that is even slightly low.
Old Nov 21, 2020 | 04:35 PM
i-w's Avatar
i-w
i run Valvoline VR1 10-30. no problems.
we should meet up sometime. i am near DC as well.
Old Nov 22, 2020 | 12:12 AM
Ozzie H.'s Avatar
Ozzie H.
For multi-viscosity oils Ford recommended 10W-30 or 10W-40 for -10F to +90F. If you use single viscosity, it would be 10W for -10F to +32F.
Be sure to use an oil that has sufficient additive to protect your flat tappets' cam.
I agree, the Valvoline VR-1 would be a good choice.
In the warm weather (above +10F) Ford recommended 20W-40.
Old Nov 22, 2020 | 05:51 AM
Colemater's Avatar
Colemater
Be sure to use an oil that has sufficient additive to protect your flat tappets.
thanks Ozzie
Old Nov 22, 2020 | 09:17 AM
Tedster9's Avatar
Tedster9
For multi-viscosity oils Ford recommended 10W-30 or 10W-40 for -10F to +90F ...
What does the Operator's Manual specify Ozzie? Sounds contradictory to me.
VR1 is good oil, though technically it is supposed to be changed every 3 months, or 3000 miles. It doesn't have all the detergents or dispersents to control sludge that extended drain interval oils do. It is a true racing oil, whether the conventional or synthetic flavors.
I know motor oil is a personal thing with a lot of people, but in most cases the operator's manual will tell you what you need to know. It would be useful to know the actual oil pressure of your motor. 1977 was a long time ago, it may have had main and rod bearing replacement and low end work done since then. Or not. The actual bearing clearances are important to judge whether an oil viscosity is suitable.
Old Nov 22, 2020 | 06:06 PM
Ozzie H.'s Avatar
Ozzie H.
The Owner's Manual specifies what I wrote.
Below +32F 5W-30
-10F to +90F 10W-30
-10F to +90F 10W-40
Above +10F 20W-40
In a footnote for the 5W-30 it says "Where sustained driving and/or high speed operation above 60 MPH is anticipated, use the next heavier viscosity oil.
Where is the contradiction?
The original question involved temperatures down to 0 degrees F in winter.
Ford recommended oil changes at 5 months or 5,000 miles, whichever occurs first. If severe operations: 2.5 months or 2,500 miles, whichever occurs first.
Other oils beside the VR-1 could be found that would protect the camshaft also.
Old Nov 22, 2020 | 07:23 PM
Tedster9's Avatar
Tedster9
Well OK maybe not a contradiction, though that's quite a spread. I'd sure want to use 10w30 in the winter before ever using 20w40, unless maybe it's an oil burner and the rods are a knockin'.
The problem with most of the motor oils that still contain phosphorous/zinc, is they usually want $18 a quart. I'm not poor but jeeze.
Old Nov 22, 2020 | 07:26 PM
ford390gashog's Avatar
ford390gashog
Thats why Rotella T6 5w40 is a common go to for me and others year round. Doesn't break the bank and has all the requirements.
Old Nov 22, 2020 | 09:54 PM
tbear853's Avatar
tbear853
I've usually used 10w30, but I have added a quart of 20w50 at times, though rarely. I have several gallons Delo 15W40 I had bought for a bike that was sold, might use it next.
neilc88
General Diesel Discussion
Dec 29, 2013 04:34 PM
Big_Dom
Nov 26, 2010 03:28 PM
Moto Mel
1983 - 2012 Ranger & B-Series
Jan 28, 2009 09:22 AM
Fordrules
15
Jul 12, 2007 07:05 AM
Pablo-UA
Aerostar
21
Jan 23, 2006 04:42 AM
