Access denied Cloudflare?
Old Mar 16, 2021 | 07:29 AM
  #61
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I had to pick out bicycles and boats on another forum (on gardening) just yesterday, even while in the middle of the process for signing up to join that forum. The disruption to my sign up was by Cloudflare, so no, it isn't just FTE.
Old Aug 20, 2021 | 08:30 AM
  #62
BPofMD's Avatar
BPofMD
Veteran: Navy
OK. what's going on with Cloudflare now? It won't connect me while using Firefox. VPN of OFF Message says "Checking your browser before accessing ford-trucks.com. " I was already in the site when this happened. Using Edge to get in to write this. Just don't want to continue using Edge. No problems using Firefox to get into any other sites.
Old Aug 20, 2021 | 08:46 AM
  #63
BPofMD's Avatar
BPofMD
Veteran: Navy
OK, now it has let me in. Must be the powers that are are screwing around with the site again. Was able to get into other Internet Brands wen sites go must have been just FTE.
Old Aug 26, 2021 | 10:07 AM
  #64
BPofMD's Avatar
BPofMD
Veteran: Navy
OK this is getting stupid.... Cloudflaire won't let me in again using Firefox. OK in Edge.... Happening this date and time.
Old Aug 26, 2021 | 10:16 AM
  #65
BPofMD's Avatar
BPofMD
Veteran: Navy
Screenshot:
Old Sep 5, 2021 | 07:44 AM
  #66
BPofMD's Avatar
BPofMD
Veteran: Navy
Doesn't FTE monitor this thread at all ? Why doesn't FTE like Firefox browser ? I keep getting the above screen and can't get in using my fav browser - FIREFOX.
OK, now I believe that the techs are doing something with the site when I get this message.... it was "OFF" about 15-20 minutes, now is working normally again. I dang sure didn't do anything different to my computer when it happened. I was down in the State Chapters when it shut me out. At least I wish you'd let me know I ain't going nuts !
Old Sep 5, 2021 | 10:08 AM
  #67
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
"Nuts" did you say?
Now we're listening!
Old Sep 5, 2021 | 06:44 PM
  #68
ctubutis's Avatar
ctubutis
I see the posts, but I am a volunteer (like almost everybody else) and there is nothing I can do about Cloudflare problems/transient network problems/whatever the cause might be (there are a ton of possibilities).
Nobody tells *us* when they do maintenance work, either. The best thing to do IMO is 1) Try another browser, or 2) Try again later.
Old Sep 7, 2021 | 06:12 AM
  #69
BPofMD's Avatar
BPofMD
Veteran: Navy
Thanks for the comeback. Appreciate you for volunteering here on FTE. Who do YOU contact when you need to clarify an issue? How do I contact someone that CAN answer me about this issue? There's gotta be a way or place on here to get site issues resolved .
Old Sep 7, 2021 | 11:32 AM
  #70
ctubutis's Avatar
ctubutis
I have to do the same as everybody else - I ask for help by posting in a forum and hope that somebody responds.
Old Sep 8, 2021 | 07:12 AM
  #71
BPofMD's Avatar
BPofMD
Veteran: Navy
OK...I give up.
Old Sep 8, 2021 | 08:02 AM
  #72
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Y2KW57
Checking your profile, it appears that you have used 389 IP addresses to access FTE, many of which are from VPNs.
Please understand that VPN's are not supported by FTE, nor does the use of VPNs appear to be consistent with Internet BrandsTerms Of Use .
Unfortunately, many online miscreants around the world tend to use VPN's to try and hid their IP address while they spam FTE. Perhaps your VPN has been used by known bad actors?
Perhaps you can try accessing FTE without a VPN?
I too use Norton's VPN and I have no problem getting in the system. If you are using some other companies software for VPN use I suggest contacting them .
I abandoned all those VPN things, the 'net os toooo slow as it is right now without bouncing my connection all over the frickin' globe...
it's happening again. Use my VPN - get the message - turn it off and no problem entering the site. Come on guys can't you just leave what works alone ? Worked fine yesterday with my VPN on.
Actually is ISN'T working again. I had my VPN turned off.
Come on guys...Cloudflair is doing irt again... getting same no access msg as in post #49. Turn off VPN and get in....turn it back on while in FTE and I can stay in FTE.
It isn't that your continued reports of not being able to access FTE with your VPN on have not been heard.
It sounds like continuing to try to use your VPN to access FTE doesn't work.
IB has stated that VPNs are neither supported nor recommended.
You have stated when you turn your VPN off, you can get into FTE.
When this thread was created, there was an actual and universal denial of service issue, that was resolved a long time ago.
Your continued reports are in isolation, and appear to be related to your wanting to use a VPN to access FTE, which IB doesn't support.
Old Sep 8, 2021 | 04:41 PM
  #73
BPofMD's Avatar
BPofMD
Veteran: Navy
Have NOT used the Norton (or any other) VPN since 08/20/21 when I saw the above message about the Virtual Networks.
BuiltToughF250
Mar 16, 2004 11:59 PM
