Access denied Cloudflare?
Old Feb 5, 2021 | 01:19 PM
  #46
T diesel's Avatar
T diesel
Originally Posted by Y2KW57
Taken care of!
The IT folks with the keys to the dials, buttons, and ***** have now cleared the issue.
We should be good to go to carry on as normal.
Thanks for your patience.
Nope.
Still locked out.
Old Feb 5, 2021 | 01:35 PM
  #47
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by T diesel
Nope.
Still locked out.
It's been a few days since you've last posted, and when you last posted (on Sunday, January 31, 2021), we were still being assertively protected by Cloudflare's services. That switch wasn't turned off until Monday morning.
Therefore, may I suggest that you close your browser, after clearing all cookies, and try again? No one else but you has reported the continuation of the issue past Monday, and it is now Friday, February 5, 2021.
Old Feb 6, 2021 | 02:58 PM
  #48
T diesel's Avatar
T diesel
NOPE.
Old Feb 6, 2021 | 03:57 PM
  #49
RLXXI's Avatar
RLXXI
NOPE.
That's odd, I can access the site with my VPN turned on. I use Norton 360.
Old Feb 7, 2021 | 02:16 AM
  #50
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
NOPE.
I'm sorry to read that you are having such issues.
No one else, in any subforum, has reported any issues since last Monday, so your situation appears to be isolated to only you.
Checking your profile, it appears that you have used 389 IP addresses to access FTE, many of which are from VPNs. The photo you posted identifies that you were using a VPN when you encountered the issue that you are complaining about.
While other members, such as the member whose post followed yours, report success with using a VPN, please understand that VPN's are not supported by FTE, nor does the use of VPNs appear to be consistent with Internet BrandsTerms Of Use .
Originally Posted by Internet Brands Terms Of Use
Users may not circumvent any technological measure implemented by us to restrict the manner in which content may be posted on our sites and services or to regulate the manner in which content (including but not limited to email) may be transmitted to other users. This prohibition includes, without limitation, a ban on the use of multiple email addresses (created via an email address generator or otherwise); the use of multiple IP addresses (via proxy servers, modem toggling, or otherwise); CAPTCHA circumvention, automation or outsourcing; multiple and/or fraudulent service accounts, including phone-verified accounts; URL shortening, obfuscation or redirection;
Unfortunately, many online miscreants around the world tend to use VPN's to try and hid their IP address while they spam FTE. Perhaps your VPN has been used by known bad actors? Perhaps you can try accessing FTE without a VPN?
In any event, whereas last weekend, the Cloudflare check was reported by many members and many moderators, this weekend, the Cloudflare vetting process is only reported by you. This strongly suggests that something isn't resolved on your end, as no one else is reporting an issue. We can only wish you the best of luck in solving it.
Old Feb 7, 2021 | 08:07 AM
  #51
BPofMD's Avatar
BPofMD
Veteran: Navy
I too use Norton's VPN and I have no problem getting in the system. If you are using some other companies software for VPN use I suggest contacting them .
Old Feb 8, 2021 | 03:44 PM
  #52
RLXXI's Avatar
RLXXI
Heh, spoke too soon, just tried to login using the Norton vpn and now I'm getting the error as reported above. Turn it off I can log in easily.
Old Feb 8, 2021 | 08:09 PM
  #53
ctubutis's Avatar
ctubutis
I abandoned all those VPN things, the 'net os toooo slow as it is right now without bouncing my connection all over the frickin' globe...
Old Feb 18, 2021 | 07:52 AM
  #54
BPofMD's Avatar
BPofMD
Veteran: Navy
Here it is - a week (or so) after this happened. it's happening again. Use my VPN - get the message - turn it off and no problem entering the site. Come on guys can't you just leave what works alone ? Worked fine yesterday with my VPN on.
Old Feb 18, 2021 | 08:07 AM
  #55
ctubutis's Avatar
ctubutis
The 'net is just toooooooo overloaded these days....
Old Feb 18, 2021 | 12:34 PM
  #56
BPofMD's Avatar
BPofMD
Veteran: Navy
So what have to do with THIS site ? It's still garbage in, garbage out !
Old Feb 18, 2021 | 09:42 PM
  #57
BPofMD's Avatar
BPofMD
Veteran: Navy
It's working again. Thanks to whoever fixed it !
Old Feb 19, 2021 | 03:14 PM
  #58
BPofMD's Avatar
BPofMD
Veteran: Navy
Actually is ISN'T working again. I had my VPN turned off. What is error 1005 ? This is weird - if I stay here and turn my VPN on, open FTE in a new window, I can get in ! WTH is going on?
Old Feb 20, 2021 | 05:40 AM
  #59
ctubutis's Avatar
ctubutis
My suspicion is broken/exceedingly slow VPN connections. (which are the routes taken between you and the servers) and all the flipping back and forth requires new IP addresses which can phuque with your cookies. I have no real evidence of this, it's just my suspicion based on what you're saying. :
Old Mar 16, 2021 | 07:11 AM
  #60
BPofMD's Avatar
BPofMD
Veteran: Navy
Come on guys...Cloudflair is doing irt again... getting same no access msg as in post #49. Turn off VPN and get in....turn it back on while in FTE and I can stay in FTE. Why just this site ? Or is Cloud-ain't fair- only used here ?
