distributor swap
Old Nov 18, 2020 | 07:05 PM
texasjr's Avatar
texasjr
distributor swap
I have a 1973 390 with the points dist I would like to change it to electronic dist any suggestions would be helpful thanks
Old Nov 18, 2020 | 07:14 PM
440 sixpack's Avatar
440 sixpack
There's lots of import aftermarket junk out there. personally I'd buy a factory Duraspark set up if my FE didn't already have it.
The Durashart has it's shortcomings but it's still better than most.
Old Nov 18, 2020 | 07:54 PM
Christmas's Avatar
Christmas
Pertronics seems to be the go to around here.
Old Nov 18, 2020 | 08:36 PM
440 sixpack
their coils are made in China, not sure about the other stuff but I'd be suspicious.
Old Nov 19, 2020 | 01:05 PM
F-250 restorer's Avatar
F-250 restorer
For more than 10 years I have run a stand alone DS2 distributor with an MSD 6A box. It works well and is torquey. If you use a DS distributor, buy an NOS (new old stock) motocraft stator unit on Ebay. It'll run you about $15. The oem motocraft ones last about 40 years. The ones you get in the parts store (China) last about 2 years. I know that from experience. If you don't want to use the MSD box, you can wire a DS2 dizzy through a GM 4 pin module too, but it'll have less spring in its step, so to speak. Good luck.
Old Nov 19, 2020 | 04:09 PM
buckin69bronco's Avatar
buckin69bronco
The duraspark distributor with a MSD ignition box is a good setup. The DS distributor is a very simple magnetic pickup and feeds the MSD box or any other ignition box that has magnetic pickup input.
Old Nov 20, 2020 | 11:26 AM
F-250 restorer
Summit offers an ignition box with the same spark energy as the MSD, and the Summit box costs about $50 less than the MSD.
*I have noticed that running so much current through my dizzy makes the contacts in the cap and rotor (all brass) corrode a bit. That makes me change them once a year—for free! I purchased the more expensive type through O'reiley's auto parts, and they came with a life time warranty. I've replaced them for free about 6 times.
Old Nov 21, 2020 | 10:18 AM
Mark Shelton's Avatar
Mark Shelton
I have a '73 with 360. I went with the pertronix setup. I did the coil, distributor that goes in the factory location, new wire and new plugs. The driveability is far superior to what I had. The price was decent and I was able to figure it all out with my limited mechanical knowledge.
Old Nov 21, 2020 | 08:43 PM
bigoldtruck's Avatar
bigoldtruck
6 months ago I bought one on ebay for $200.00. The seller's name is "theswapmeetparts". Description of my distributor is "Small cap Ford F390 (etc) blue HEI distributor + 45K coil + plug wires." It fits alongside the big Edelbrock air cleaner, that is why I got the small cap type. (Air cleaner has a 3/4" shim under it also.) The distributor came with a steel gear, and I think my cam is cast iron. So I got a brass gear from Jegs and put that on. Big improvement over my worn-out points distributor. If I had it to do over again I would look for something that came with a cast iron gear on it. My brass gear was $50.
Old Nov 23, 2020 | 06:57 PM
texasjr's Avatar
texasjr
thank you all appreciate your help
Gabes50
Oct 20, 2020 07:59 PM
knibbeone
Large Truck
Feb 23, 2020 10:21 PM
xphr8r
Jun 22, 2016 05:16 AM
whisler
Dec 11, 2011 07:42 AM
Matt66
Oct 18, 2005 10:20 PM
