Help with distributor swap
Old Jun 20, 2016 | 07:45 PM
xphr8r's Avatar
xphr8r
Hi, I want to put my 83 duraspark dist in a 73 . the engine is a 4.9L. Any info will be appreciated. Thanks...
Old Jun 21, 2016 | 08:17 AM
Rusty Bucket Ohio's Avatar
Rusty Bucket Ohio
I am looking to replace my 86 4.9L distributor with an older points one ... can't adjust the computer like a set of points ... if yours has points I would be interested in a purchase. As far as Your swap ... Can't help you there ... Carl
Old Jun 21, 2016 | 03:02 PM
1986F150six's Avatar
1986F150six
Welcome to the forum, xphr8r & Rusty Bucket Ohio!
Use the "search" feature at the top of the page and you will find much to read. Here is a link which will get you started, xphr8r:
https://www.ford-trucks.com/forums/1...on-how-to.html
Old Jun 21, 2016 | 03:58 PM
Rusty Bucket Ohio
Awesome ... Thank You
Old Jun 21, 2016 | 06:39 PM
FuzzFace2's Avatar
FuzzFace2
If I have a points dist I would get Pertronix Performance Products setup. A few wires to hook up and you are done.
Dave ----
Old Jun 21, 2016 | 08:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DuraSpark electronic ignition introduced in 1974, but not all FoMoCo vehicles came with it until 1976.
Old Jun 22, 2016 | 05:16 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So do you have the entire '83 vehicle?
You need the harness, module, coil and distributor.
A bypass wire from the 'I' terminal of the fender mounted starter relay, and a coil resistor (ballast or wire)
Jim'sRebel has some great pictures of the DSII installation on the I-6.
1984oldn’slow
Jan 31, 2019 04:05 PM
mprima
Jan 23, 2018 10:49 PM
Yogiesford
1961 - 1963 F100 Unibody
Oct 15, 2017 02:57 AM
whisler
Dec 11, 2011 07:42 AM
68 ranger
Sep 21, 2008 08:40 PM
