Upgrades list.
Old Nov 21, 2020 | 08:27 AM
  #31
RacinJasonWV's Avatar
RacinJasonWV
Originally Posted by RoosterCoggburn
I was offered a GTP38R that has R+R billet wheel, 100,000 miles on it for $900. Been reading hard on the GTP38R and it sounds good. But if I needed to replace the center section I'm in it for another $650.
I'm not sure a T4 setup is what I need either though. I dont want to go too far down the rabbit hole. I would like to keep stock injectors for as long as possible and just run a tune for little more power when towing. Will a T4 setup run on stock Injectors?
After you guys install a billet wheel on the stock journal bearing turbo do you have it balanced by a shop? Also looking at the drop in ready balanced KC turbine/compressor setup for the stock turbo but it's $450 or so.
Stay away from a modified 38r. At least that’s what I have been reading lately.
T4 would be fine but I think for your current goals it may be overkill.
I would say rebuild your turbo with the KC turbine and Riffraff 4x4 wheel (per Wes444’s testimonial). The parts are individually balanced so you don’t need to balance the set. This is the cheapest route for you to try and this will satisfy most folks needs.
You should also give KC a call to get their expert advice. A stage 1 may be a good fit if you plan to do injectors soon. But if not, then the rebuild or KC “stock plus” may be a better choice for now.
Ultimately the choice is yours. I’m just a random nut on a forum.
Chiroguyf250
2015 + Expedition & Navigator
Jun 11, 2020 02:44 PM
tom1979
20
Aug 28, 2009 11:04 PM
tr0y
Feb 5, 2008 09:08 PM
charon61285
16
May 21, 2005 01:47 PM
