Hi, I bought a 93 f250 5.8 and have been fixing it up one problem at a time. The electrical issue I’m having is when the truck is running the needles of the oil pressure and voltage gauge are acting up. The more power I draw (lights, heater blower) the oil pressure gauge jumps higher and the volt gauge drops lower. Now I know the oil gauge is a dummy gauge so it’s just reading different voltage. I have checked the voltage at the battery. Not running I have 12.5 and running I have just over 14. Turning my lights on or turning the blower on doesn’t effect voltage at battery so I am assuming the charging system is fine. I am getting ready to start checking wires and grounds, but I wasn’t sure if maybe this was a bigger problem. The idle also sometimes drops lower when I draw more power sometimes to the point where is wants to stall at idle.
Did you ever find out the cause of your gauges jumping? My '89 does the same thing. I can turn the blower up or the lights on and the oil pressure gauge will go up.
Yes I did. Turned out to be a grounding issue. I learned that the oil pressure gauge is more of a dummy gauge. Once the pressure sensor hits a certain amount of pressure it sends a signal to the gauge. The gauge isn’t reading actual pressure. These trucks are known for their issues with bad grounding so I ran two new grounds from the battery. One to the frame and one to the cab. And that corrected the problems I was having.
where did you run them to on the frame and where onthe cab?
Bear with me here I did this a couple years ago and I no longer have the truck.
I went to the local auto parts store and picked up a couple pre made grounding cables you can get various lengths of. The one to the frame I just found an existing hole along passenger side of frame, wire wheeled the area around the hole to remove paint and rust, and bolted it there.
For the cab ground I believe I ran it just to an existing spot where there was already a grounding cable but my memory is hazy on that one. And mind you before doing this I would inspect and clean all existing grounding cables first to see if that helps.
Its funny I asked becuase I was just going to make sure you didnt cause any dirty grounds which I dont think you did. basically when your ground path has the ability to pull other circuits high or low because of the sensitivity to constant/expected readings
