351M no start?
Old Nov 16, 2020 | 03:19 PM
Dman Heafner's Avatar
Dman Heafner
Originally Posted by 440 sixpack
If you decked the block and shaved the heads you may have to get your intake machined to match the new angle. normally it's not enough to prevent a seal up but since you seem to be having unusual problems maybe looking at extreme answers is in line.
We didnt do any machining on the heads or intake, they were fine looking to me, so just a good *** clean and new gaskets. Im just confused why it started 3 weeks ago and not now. If the answer is extreme it is what it is, and ill rebuild the thing into a 400.
Old Nov 16, 2020 | 03:21 PM
Dman Heafner
You might check the voltage to your coil . wear spark might be the problem . an ECM can fail at any time for no reason. I'd swap the old one back just to eliminate that possibility.
Figure out for sure what the liquid is that will make it a lot easier to diagnose.
Also, cant swap in the old ECM, tossed that sucker when I got the new one. All the goo/insulation stuff had already melted and ran down the fender so I figured there was no use in keeping it.
CanOfBeans
59
Apr 12, 2020 08:59 PM
big daddy chuck
Mar 7, 2006 08:21 AM
79 sb150
23
Jan 11, 2006 11:13 AM
justdan
13
Mar 28, 2005 07:19 PM
dougas
Aerostar
May 8, 2002 09:43 AM
