Water pump crapping out!🤨
Old Nov 13, 2020 | 01:27 PM
Listor's Avatar
Listor
Well seems it’s my water making all noise , replaced the idler and tensioner pulleys , anything I should do while I’m in there!
Old Nov 13, 2020 | 02:53 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Coolant refresh/change?
Exhaust back pressure sensor and tube OK?
Fan clutch functioning?
Fan free of cracks and damage?
Use a piece of cardboard or wood behind the radiator to protect it if the fan falls forward.
Other than that, get'r'dun...
Old Nov 13, 2020 | 09:03 PM
udsuth78's Avatar
udsuth78
I did mine a couple weeks ago, and I went for the oil cooler rebuild as well. You'll already have it halfway off doing the pump so it makes sense if it hasn't already been done. I think it only added an hour to the job.
Old Nov 14, 2020 | 06:59 AM
Listor's Avatar
Listor
Originally Posted by Sous
Coolant refresh/change? Might do a good flush
Exhaust back pressure sensor and tube OK? hmm maybe i can get a new sensor , and clear it out
Fan clutch functioning? yep fan works fine
Fan free of cracks and damage? no issues there will inspect once i get it out
Use a piece of cardboard or wood behind the radiator to protect it if the fan falls forward. will do!
other than that, get'r'dun...
bp sensor has been bad all along, keep forgetting to get a new one, cleared the tube out , will look at it again
Listor's Avatar
Listor
good plan!
BuckHammer
135
Jun 9, 2012 11:35 AM
nates-new-old-f150
Apr 2, 2008 02:24 PM
ginsan67
Aerostar
May 1, 2005 07:42 PM
