Transmission fluid change on E4OD
Old Nov 11, 2020 | 05:58 PM
Flyview's Avatar
Flyview
Arrow Transmission fluid change on E4OD
Hey everyone, thank you in advance for all of the great advice I've found on this forum.
I have a 1992 Ford E250 5.8L that is at 143.5k miles. I've looked in the owner's manual and it doesn't say anything about replacing it in that section or in the scheduled maintenance. It says the fluid required is stamped on the dipstick. On the handle of the dipstick I see in very faint writing what appears as "SE MERCON". At the very end of the dipstick that sits in the fluid, there are markings for "HOT", "COLD", "E4" and a small "Z" or "N". It has an overdrive button on the gear selector. Does this mean I have the E4OD transmission?
Should I change the fluid? What is the recommended fluid/filter change interval? What is the recommended fluid and filter for my transmission? The fluid on the dipstick appears very clean pink. I have no issues with the way it's shifting. It takes about a second to engage the selected gear but I assume that's normal.
Old Nov 11, 2020 | 06:35 PM
ford390gashog's Avatar
ford390gashog
The correct fluid according to Ford is Mercon V. The original Mercon was discontinued and is no longer licensed. So any Fluid out there that days Mercon is up to the manufacturer of what's really in it.
Old Nov 11, 2020 | 06:54 PM
Spaznaut's Avatar
Spaznaut
Do a search and read up on it. I have a '92 with the e40d and used synthetic. Mine trans is going out so I changed my fluid and put a big cooler on it to extend it a year or more before I have to rebuilt.
Old Nov 11, 2020 | 08:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I recommend 30,000 mile change intervals. Here is how to do it: https://www.ford-trucks.com/articles...-transmission/
Old Nov 12, 2020 | 06:16 AM
baddad457's Avatar
baddad457
If you're going to keep the van any length of time, install a drain plug in the transmission pan. It makes life so much easier to drain 3 gallons of fluid. (what's in the pan)
Old Nov 12, 2020 | 07:48 AM
Mark Kovalsky
There is about 2 gallons in the pan.
Old Nov 12, 2020 | 07:51 AM
JWA's Avatar
JWA
I've done exactly that even though I could avoid ever draining the pan using Mark K's method of a full fluid exchange. I use the better quality Quick Change fittings found at Unique Truck Equipment. They're not cheap but I like the way they allow me to drain the pan without any mess. Always tough working in the driveway!
Old Nov 12, 2020 | 11:35 AM
baddad457's Avatar
baddad457
Potato-potatoe doesn't matter, it's a huge mess trying to drain it without a drain plug. I don't agree with your 30K interval either. 4 gallons is a big expense especially as I recall, Ford recommends it done at 100K.
Old Nov 12, 2020 | 11:36 AM
baddad457's Avatar
baddad457
Old Nov 12, 2020 | 05:56 PM
Mark Kovalsky
Not everyone does. That's fine.
Old Nov 12, 2020 | 06:14 PM
surfref32's Avatar
surfref32
I believe that is for the newer stuff. I recall seeing something about 30k for heavy use on my E4OD trucks. I'd expect a premature failure going to 100k on the older trucks especially since mine were 8,000 lbs every day with hard city duty
Old Nov 12, 2020 | 07:53 PM
ford390gashog
Well newer trans fail with 100k service, plenty of stuck solenoids in them. The cost of a fluid change is under 100.00 and every 30k its just a operating expense.
Old Nov 12, 2020 | 10:55 PM
baddad457's Avatar
baddad457
I've got 155K on mine now, (96 E150 conversion van) No signs it's going to give up anytime soon. First fluid change was at about 100K. I changed it again last year before going to Colorado at 150K. I've towed a 5,000 lb trailer a few times and my custom built 500 lb utility trailer several trips out west. I sold my 95 E150 about 15 years ago, it had about the same mileage on it's E4OD (and also two fluid changes), it had developed an OD shudder a year before I sold it, Fixed that with a bottle of Lucas Transmission treatment. Stuff also worked wonders on a 40 year old C6 that had 60K on it without ever having it's fluid changed. After adding a quart of Lucas to it, it was shifting like new after a trip around the block.
Old Nov 13, 2020 | 08:36 AM
Mark Kovalsky
The trans treatment replaces the additives that wear out of the trans fluid. Replacing the fluid would have also fixed the problem, and then you'd have new fluid, too.
Old Nov 13, 2020 | 11:31 AM
baddad457's Avatar
baddad457
In that old C6, yea, the E4OD had fairly fresh fluid.
