Oil brands
Old Nov 15, 2020 | 07:44 AM
  #31
Lin19687's Avatar
Lin19687
Veteran: Navy
Originally Posted by Chris 86
It's made by Warren, same company that blends Supertech, and Amazon basic oil.
Thanks, That's too bad.
Old Nov 15, 2020 | 09:01 AM
  #32
1dryfly's Avatar
1dryfly
I use Mobil 1 5-30 full synthetic and Motorcraft filters. Get the Fumoto valve if you want to change your own.
Old Nov 15, 2020 | 09:04 AM
  #33
mcmurm's Avatar
mcmurm
Originally Posted by ShotgunZ71
Indeed, it is. Blended by Warren Distribution, not to be confused with Warren Oil, which is the house brand. They have come a long way from the “corner store oil” they used to be known for. They used to say that NAPA was made by Valvoline, but it could be different now. I’d be tempted to use Amazon oil at some point once warranty is out. Even the fact of doing your own changes is risky to some regarding warranty claims. I’ll take my chances on that one. Every maintenance item is documented on my vehicles, whether they have warranty or not.
I wouldn't be afraid of the Amazon oil, it has actually tested very well for gas motor use. With that said, I don't find it price competitive to Rotella T6 Full Synthetic, which meets Fords new spec for diesel and has pretty extensive use in the 6.7 PSD.
Old Nov 15, 2020 | 10:50 AM
  #34
Cletus Hogwallop's Avatar
Cletus Hogwallop
Originally Posted by killjoykarl
not sure if the 6.2 likes something different
If you want an opinionfest, ask random people on the innerwebs.
If you want the proper oil for your application, use any oil that meets or exceeds the specs in the Owner's Manual.
Old Nov 15, 2020 | 10:55 AM
  #35
Cletus Hogwallop
Originally Posted by '65Ford
don't switch from brand to brand. Two different brands can meet the same spec but have chemistries that don't mix well.
Heard this back in the late 70's. Still have yet to see any evidence that this holds true. If it were true, hundreds of millions of engine failures would be occurring, yet 400K out of a modern engine is to be expected.
Old Nov 15, 2020 | 11:07 AM
  #36
Joe T's Avatar
Joe T
I worked at a shop in highschool changing oil and the regulars that drove a lot and went to other places using different brands would have leaks and always be a little low on the initial check. If they stuck with us that wouldnt be the case. That was back when it was normal to change every 3,000 miles.
So I would try to stick with the same brand and weight. Weight needed can change as you get higher miles though.
To keep it simple I would suggest the typical factory fill for the first couple oil changes then change it up and stick with it.
For Ford they have their IOLM and dummy light turn on and Motorcraft semi-synthetic is what Ford uses. So I would change it up to only a full synthetic.
Old Nov 15, 2020 | 11:33 AM
  #37
Cletus Hogwallop
Oil threads...they go on for decades with little to no conclusion.
Brand is marketing, plain and simple. But, just like politics or religion, many will fight to the absolute death to defend their favorite brand.
Weights can change, and most manufacturers suggest weight changes based on climate conditions for the season. Being from Texas, I just use one weight, but that is happenstance, not a strategy. I would have zero concerns changing oil weights based on climate changes during the year if I lived where that mattered.
https://www.thedrive.com/article/127...d-a-decade-ago
I trust outfits like BlackStoneLabs as I believe they are brand agnostic. YMMV. That, and they have data from a broad spectrum of vehicle operators, vehicle manufacturers, geographic locations, and a large array of brands as real world samples. IMO, this is where reality occurs, vs opinion, belief, or advertising verbiage.
Attached is the full report, for the morbid details.
File Type: pdf
Old Nov 15, 2020 | 12:43 PM
  #38
'65Ford's Avatar
'65Ford
Kinda tough to be more factual then hearing it from the chemists who make the oil formulas and then test them in engine labs. If your engine or anyone else's engine failed due to mixing oil brands, how would you know? Can you or most other people test it in a way that traces the root cause to the oil instead of a mechanical flaw? These guys do it for a living.
As for Valvoline putting out info on "myths". There's technical info from engineers and chemists, there's marketing spin, there's legal advice, etc. It's up to us to sort through the info for the actual truth.
Like I said earlier, probably never notice a problem by mixing but why do it?
Old Nov 15, 2020 | 01:03 PM
  #39
Cletus Hogwallop
Promise I'm not trying to be argumentative, I just don't see how modern or recent engines can be that flawed that the residual oil after draining would be an issue if a different brand was used for the fill.
Perhaps the chemists have a reason, but in the real world, this would be catastrophic for the automotive industry if anything significant arose from it. Reason I use different brands is because I've never known of any failure or premature demise due to using various oil brands in the same engine.
Most additives are trace amounts. The residual additive amount from the residual oil after a drain cannot amount to any negative result.
IMO, all we need to care about was in the BlackStoneLabs report...and that is, it really doesn't matter.
If only we rode our politicians like we ride oil brands, lol....
Old Nov 15, 2020 | 01:04 PM
  #40
BillyE's Avatar
BillyE
What was the last oil-related engine failure you’ve heard of? Don’t overthink it.
Old Nov 15, 2020 | 01:19 PM
  #41
Cletus Hogwallop
^^^ Zacly.
Old Nov 15, 2020 | 02:43 PM
  #42
Kellem's Avatar
Kellem
These oil threads remind of the ole'......" should I flush my transmission " threads. Lol
Old Nov 15, 2020 | 03:00 PM
  #43
ejb69's Avatar
ejb69
I have been using Mobil 1 for over 30 years and never had an issue. Not saying Mobil is the best, just that it works for me.
Old Nov 15, 2020 | 03:52 PM
  #44
Chris 86's Avatar
Chris 86
AMSOIL also says on their website that you can mix their product with other oils. They just say to use the lower of the two oil's change intervals if mixing.
Old Nov 17, 2020 | 07:02 AM
  #45
killjoykarl's Avatar
killjoykarl
Anyone try amsoil signature 25k mile oil and how did it look after the change.
