VBELT HELP
Old Nov 10, 2020 | 02:08 PM
Mikey21's Avatar
Mikey21
VBELT HELP
Retarded question, and I think it’s been answered before but I just can’t find it, how in the ever loving world do I change these V-Belts, the one that runs from the alternator to the fan just basically disintegrated
Old Nov 10, 2020 | 04:51 PM
DarkOverCast's Avatar
DarkOverCast
Remove the first two to get to the alternator belt.
The AC bracket has several bolts you have to loosen to get it to pivot. It has a square in it for a 1/2" breakover bar as well as the power steering bracket.
The vacuum pump has a 3/8" square
I use a long prybar to tension the alternator. Loosen the pivot bolts on your accessories as well
Old Nov 10, 2020 | 07:02 PM
Mikey21's Avatar
Mikey21
How do I remove that belt , and then put another on, maybe I’m retarded but I’m confused as ****
Old Nov 10, 2020 | 07:31 PM
DarkOverCast
Okay, on the AC bracket, there's like three or so bolts you have to loosen and one or two on the back side. Then the whole bracket will pivot to loosen or tighten the belt.
On the power steering you have an upper bolt that's the pivot, and a lower belt almost hidden by the pulley (passenger side of pulley) that is the tension bolt. Iirc its a 5/8", once loosened it also pivots.
Brian1971f100
29
Mar 18, 2021 08:27 PM
foofees
15
Jul 7, 2017 03:19 PM
ltmadsen
1983 - 2012 Ranger & B-Series
Apr 24, 2017 12:06 PM
jaybob1807
15
Apr 22, 2011 11:40 PM
slenser
Sep 20, 2006 08:41 PM
