I am missing the lower bolts that attaches the fender to the cab on both sides on my 85 F250. I literally laughed out loud when I noticed. Looking for what size of bolt and nut I can pickup.
From the factory manual, there is one bolt going through the cab to a nut mid way up the fenders. Then a bolt, some sort of shim, and a nut on the lower part of the fender that attaches to some support off the bottom of the cab?
Lining up an appointment with a chassis shop to get my frame straightened and get my bumper and doors lined up finally. I am sure missing those bolts will be an issue. Frame straightening regardless.
The two bolts and nuts that fasten the fender to the cab at the top are the same as the two you are looking for.
