Truck fluids
Old Nov 11, 2020 | 11:00 PM
Evan76's Avatar
Evan76
type f is one of the grippiest trans fluids out there. The c6 will be fine run on just about anything but water. Id personally if it were mine fill it with chevron thf1000 tractor transmission fluid.
Ive done quite abit of testing fluuds in my auto in my cummins pickup
Fordf dex's atf4. I do run the thf1000 in it. Change it about ever10k crisper shifts and temp gauge shows less heat wich means its slipping less with thf1000. Spec is atf+4
I run chevron 15/40 in everything with a crank case. My 76 has it with zinc additive
And bottle that says brake fluid works
80/90 gear oil in the difs. The 1000 in diffs when in a pinch.
Old Nov 12, 2020 | 10:37 PM
GarageBound's Avatar
GarageBound
check out this site and we'll see you in a week. You'll get lost in the content.
https://bobistheoilguy.com/forums/
Old Nov 12, 2020 | 11:28 PM
Ozzie H.'s Avatar
Ozzie H.
Reading your owner's manual will tell you what Ford recommended in 1977. Specifications may have changed on some of the fluids, but it's at least a start.
Old Nov 14, 2020 | 09:25 AM
Tedster9's Avatar
Tedster9
Originally Posted by 440 sixpack
It's better to keep the moisture out of the system by repelling it than to absorb it.
It would be better, all things being equal.
The problem of course, and this is why alcohol based brake fluids were selected in the first place, is that older brake systems are not sealed to the atmosphere, as they are now, they weren't a closed system. Moisture, in the form of condensation due to temperature swings inevitably gets in.
It just sort of bugs me when brake fluid discussions always revolve around "it absorbs moisture!!!" as if this is some kind of defect and the engineers were idiots. Not pointing fingers at you or anyone, just that this characteristic is a feature not a bug.
ryanrk12
6.7L Power Stroke Diesel
Jul 30, 2019 12:33 PM
ajorn
Nov 1, 2018 06:34 PM
Kurt32
Dec 10, 2014 01:53 PM
Powerstroke_wannabe
Nov 16, 2009 06:19 PM
Gr8ride
13
Oct 2, 2001 09:43 PM
