I have a 2000 ford f150 4.2 2wd I was driving and it started up shifting and downshifting got it home put it in reverse to back in my drive way and it shudderd and cut off start it back up put it in drive and it only revs unless I rev really high it w ont move. Overdrive light is flashing. ANY HELP could it be the overdrive wires or what PLEASE HELP
The flashing OD light means that codes are stored to indicate where to start looking. Without the codes all I can tell you is that something is wrong.
I recommend Forscan to read the codes. You can download it free at www.forscan.org. You'll need an ELM327 adapter, too. I bought one from Amazon for less than $30. Get the codes and we can help.
