Smoother when cracked
Old Nov 3, 2020 | 05:09 PM
yipyip yeah's Avatar
yipyip yeah
So I recently replaced my injector lines, all the injectors, all the glowplugs, and added an electric fuel pump. NOw the eninge was running decently before adding the pump, but after installing the pump it started to act funny maybe 20 miles into driving around.
Here's the problem, the thing blows white smoke like a train and when I rev the engine it makes a clicking sound like its misfiring or something. So I started cracking the lines to see if one of the injectors are bad and I found the engine runs a lot smoother with injector #5 cracked. She stops smoking, stops clicking, it sounds good. When I re tighten it, you immediately get some clicks again.
Any Ideas? could it be the piston?
Thanks
Old Nov 3, 2020 | 06:09 PM
hairyboxnoogle's Avatar
hairyboxnoogle
If it wasnt doing it before, i have a hard time believing its a piston. Swap that injector into another hole and see what happens.
Old Nov 4, 2020 | 03:45 AM
tjc transport's Avatar
tjc transport
i ain't rite
what type e pump did you use? could be high pressure pump and a weak injector.
Old Nov 4, 2020 | 11:40 AM
yipyip yeah
Yeah so I'm not sure exactly what pressure the pump is, but i've since installed a kill switch.
The bad injector has a lot of black oil on the tip. Is this a symptom of something?
I'm gonna run some compression tests here now
Old Nov 4, 2020 | 05:44 PM
hairyboxnoogle
Wet black tip is leaking, also explains the noise and smoke
idi7.31990
26
Nov 4, 2020 05:42 AM
VT tree grower
Jul 11, 2019 05:56 PM
dishman5000
Jul 29, 2013 10:41 AM
bad12jr
16
Feb 16, 2009 08:26 PM
gweeds
Apr 19, 2008 07:58 PM
