if before the reverse level you are midway of shock travel then dropping the rear two inches will probably put you at 2/3rds shaft in the shock and 1/3rd exposed. Giving you 1/3rd on compression and 2/3rd on recovery…which is not really a good thing for towing. You can mitigate that with bags, large bumpers, summo springs, etc.
There was a thread a couple weeks back on this, sorry can’t remember the thread title. Thinking consensus was that because the 2020s only have 2 inch blocks in the back you can’t drop it a bunch. And there was some talk about pmf leveling kits.
I ordered the 1.5” blocks to replace my 3.5” factory blocks on my 19 f250 from PMF suspension and I am happy with them. Only issue I had at first was putting the blocks on the opposite sides. One side is 1 3/8” thick versus 1 5/8” thick. Make sure thinner side faces front of vehicle on both blocks.
