AOD vs E4OD
Old Nov 2, 2020 | 03:30 PM
schoo's Avatar
schoo
AOD vs E4OD
Have an AOD in my truck needed to rebuild it, a sales guy is saying I can use a E4OD kit for a rebuild is this true?
isn’t the pan bigger on the E4?
what would you recommend for a kit? From who?
Drive train is 5.0 (250+or-hp)89 AOD from a e250 van, my truck weighs 3300#
49 f1
Old Nov 2, 2020 | 05:16 PM
85e150's Avatar
85e150
AOD is a different animal than the E4OD.
The pan tells the basic tale:
http://www.fordification.com/tech/im...-transID08.gif
AOD:
Forde AOD transmission
The AOD will NOT have an electronic controller, but WILL have TV cable or linkage which must be adjusted properly for the trans to operate correctly. (No TV adjustment can lead to a quick trans failure.)
Anyway, once you are certain what you have you can order parts from that Charlie Tranny link or search for parts from other sources.
The "sales guy" needs to do some homework.
Old Nov 2, 2020 | 05:21 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Nothing that fits an E4OD will fit an AOD. He doesn't know what he is talking about.
Old Nov 2, 2020 | 05:25 PM
schoo's Avatar
schoo
Thanks I don’t see where Charlie has AOD parts
Old Nov 2, 2020 | 05:27 PM
schoo's Avatar
schoo
Thank you mark do you know of anyone selling kits made in the usa
and should I replace the bands
Old Nov 2, 2020 | 05:29 PM
85e150's Avatar
85e150
He has a parts link, which I didn't click on, but it appears he has really "nothing" as far as what you need.
First one up when you search "Ford AOD rebuild kit".
https://www.monstertransmission.com/...it_c_4326.html
Old Nov 2, 2020 | 05:44 PM
schoo's Avatar
schoo
Looked at monster a little pricey wondering if USA made
looked TCi same thing
Old Nov 2, 2020 | 06:15 PM
schoo's Avatar
schoo
is raybestos made in usa
has anyone made up their own kit ie; parts list?
Old Nov 7, 2020 | 07:18 AM
projectnitemare's Avatar
projectnitemare
If you are questioning what parts to replace, you might be better letting a shop handle the rebuild. Buy a overhaul book if you are going to attempt yourself. For something of that age, I would replace all the soft parts (clutches, bands, seals). A box kit will handle that, raybestos is what I use. I order for a supplier but you can find the kits through summit racing. For a daily driver, I would not suggest the race frictions, regular is fine. If hard parts are worn you will typically find that in the teardown. Your best bet, visit a local shop, they will sell you what you need as far as parts. You will need to buy a clutch pack compressor and some lip seal tools. Depending on your AOD, it may have cast drums, you really should have special seal installation tools for those to avoid cutting the seals, although it can be carefully done without them. Those tools are basically extinct and expensive. Good luck with the project.
Old Nov 7, 2020 | 09:02 AM
schoo's Avatar
schoo
thank you very much for your time I’m doing it myself because I don’t have anything else to do, well in the shop I’m don’t have anything
92fatford
Feb 17, 2008 08:08 AM
EgoMan
Jun 24, 2006 01:33 AM
turboguy
Mar 13, 2005 04:36 PM
rvpfly
Dec 6, 2004 01:18 PM
threefiftyone
Apr 24, 2004 12:21 AM
