If both filaments on that side are dim, I'd expect a bad ground--but swapping bulbs is an easy sanity check. Look at the wiring and plugs while you're swapping, see if anything's obviously corroded or looks like it overheated.
The problen followed the bulb. Whew, an easy one! I've seen moisture in the housing where the problem originated. I think I'll order a pair of new housings.
Thanks!
Be careful ordering new housings. A lot of the Chinese aftermarket, cheap housings will yellow very quickly and have worse sealing issues than what you are experiencing now.
I was afraid of that. I’ll keep the originals around.
